McStarfighter
Kosmokrat
Folgende kurze Frage: Ist unter FreeNAS die ZFS-interne Kompression möglich?
Danke im Voraus.
Danke im Voraus.
Noch ne Nachfrage: Welche Kompressionsmethode kommt denn da zum Tragen?
compression=on | off | lzjb | gzip | gzip-N
Controls the compression algorithm used for this dataset. The
"lzjb" compression algorithm is optimized for performance while
providing decent data compression. Setting compression to "on" uses
the "lzjb" compression algorithm. The "gzip" compression algorithm
uses the same compression as the gzip(1) command. You can specify
the "gzip" level by using the value "gzip-N" where N is an integer
from 1 (fastest) to 9 (best compression ratio). Currently, "gzip"
is equivalent to "gzip-6" (which is also the default for gzip(1)).
This property can also be referred to by its shortened column name
"compress".
