Hmm. Ich kann dir zwar jetzt sagen, was er ausgibt. Aber leider kann ich damit nicht wirklich viel anfangen *duck :
name of display: :0.0
version number: 11.0
vendor string: The XFree86 Project, Inc
vendor release number: 40300000
XFree86 version: 4.3.0
maximum request size: 4194300 bytes
motion buffer size: 256
bitmap unit, bit order, padding: 32, LSBFirst, 32
image byte order: LSBFirst
number of supported pixmap formats: 7
depth 1, bits_per_pixel 1, scanline_pad 32
depth 4, bits_per_pixel 8, scanline_pad 32
depth 8, bits_per_pixel 8, scanline_pad 32
depth 15, bits_per_pixel 16, scanline_pad 32
depth 16, bits_per_pixel 16, scanline_pad 32
depth 24, bits_per_pixel 32, scanline_pad 32
depth 32, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 255
focus: window 0x1800003, revert to PointerRoot
number of extensions: 25
BIG-REQUESTS
DPMS
Extended-Visual-Information
FontCache
LBX
MIT-SCREEN-SAVER
MIT-SHM
MIT-SUNDRY-NONSTANDARD
RANDR
RENDER
SECURITY
SHAPE
SYNC
TOG-CUP
X-Resource
XC-APPGROUP
XC-MISC
XFree86-Bigfont
XFree86-DGA
XFree86-Misc
XFree86-VidModeExtension
XInputExtension
XKEYBOARD
XTEST
XVideo
default screen number: 0
number of screens: 1
screen #0:
dimensions: 1024x768 pixels (347x260 millimeters)
resolution: 75x75 dots per inch
depths (7): 24, 1, 4, 8, 15, 16, 32
root window id: 0x37
depth of root window: 24 planes
number of colormaps: minimum 1, maximum 1
default colormap: 0x20
default number of colormap cells: 256
preallocated pixels: black 0, white 16777215
options: backing-store NO, save-unders NO
largest cursor: 64x64
current input event mask: 0xd84031
KeyPressMask EnterWindowMask LeaveWindowMask
KeymapStateMask SubstructureNotifyMask SubstructureRedirectMask
PropertyChangeMask ColormapChangeMask
number of visuals: 1
default visual id: 0x21
visual:
visual id: 0x21
class: TrueColor
depth: 24 planes
available colormap entries: 256 per subfield
red, green, blue masks: 0xff0000, 0xff00, 0xff
significant bits in color specification: 8 bits
