Hierarchische jails in CURRENT importiert
Yamagi
Possessed With Psi Powers
Teammitglied
FreeBSD 8.0 kommt näher und eines der letzten ausstehenden Features waren weiter Verbesserungen der Jails. James Gritton hat heute Nachmittag die lange gewünschte Fähigkeit eingefügt, um Jails verschachteln zu können. Es können nun also Jails in Jails in Jails und so weiter erstellt werden.
Date: Wed, 27 May 2009 14:11:23 +0000 (UTC)
To: src-committers@freebsd.org, svn-src-all@freebsd.org,
        svn-src-head@freebsd.org
Cc:
Subject: svn commit: r192895 - in head: . lib/libc/sys sys/compat/freebsd32
        sys/compat/linux sys/contrib/ipfilter/netinet sys/fs/procfs
        sys/kern sys/net sys/netinet sys/netinet6 sys/nfsserver
        sys/security/m...
Author: jamie
Date: Wed May 27 14:11:23 2009
New Revision: 192895
URL: http://svn.freebsd.org/changeset/base/192895
Log:
  Add hierarchical jails.  A jail may further virtualize its environment
  by creating a child jail, which is visible to that jail and to any
  parent jails.  Child jails may be restricted more than their parents,
  but never less.  Jail names reflect this hierarchy, being MIB-style
  dot-separated strings.
  Every thread now points to a jail, the default being prison0, which
  contains information about the physical system.  Prison0's root
  directory is the same as rootvnode; its hostname is the same as the
  global hostname, and its securelevel replaces the global securelevel.
  Note that the variable "securelevel" has actually gone away, which
  should not cause any problems for code that properly uses
  securelevel_gt() and securelevel_ge().
  Some jail-related permissions that were kept in global variables and
  set via sysctls are now per-jail settings.  The sysctls still exist for
  backward compatibility, used only by the now-deprecated jail(2) system
  call.
  Approved by:  bz (mentor)
Damit sollte man jetzt auch Tinderboxen innerhalb von Jails erstellen können :)
Tinderbox Jails sind keine FreeBSD Jails. Der Grund weshalb sich eine Tinderbox nicht ohne weiteres in einer Jail betreiben lässt ist, dass das Mounten von NFS bzw. nullfs in einer Jail nicht gestattet ist.
Nach meinem Verständnis dieses Konstrukts müsste das jetzt aber doch gehen. So verstehe ich zumindest den 2. Absatz des Logs das Yamagi gepostet hat oder sehe ich da was falsch?
