JAIL und swap_pager: I/O error - pageout failed?
happy
Wo kommt der fehler her?
swap_pager: I/O error - pageout failed; blkno 17730,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 17745,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 20796,size 16384, error 12
swap_pager: I/O error - pageout failed; blkno 31104,size 61440, error 12
swap_pager: I/O error - pageout failed; blkno 20629,size 12288, error 12
swap_pager: I/O error - pageout failed; blkno 31136,size 65536, error 12
swap_pager: I/O error - pageout failed; blkno 23594,size 28672, error 12
swap_pager: I/O error - pageout failed; blkno 24119,size 36864, error 12
swap_pager: I/O error - pageout failed; blkno 17753,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 17755,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 20422,size 8192, error 12
swap_pager: I/O error - pageout failed; blkno 20523,size 8192, error 12
swap_pager: I/O error - pageout failed; blkno 17775,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 23641,size 28672, error 12
swap_pager: I/O error - pageout failed; blkno 13024,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 31152,size 65536, error 12
swap_pager: I/O error - pageout failed; blkno 22159,size 20480, error 12
swap_pager: I/O error - pageout failed; blkno 20526,size 8192, error 12
swap_pager: I/O error - pageout failed; blkno 20749,size 12288, error 12
swap_pager: I/O error - pageout failed; blkno 20580,size 8192, error 12
swap_pager: I/O error - pageout failed; blkno 20931,size 16384, error 12
swap_pager: I/O error - pageout failed; blkno 17788,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 20817,size 12288, error 12
swap_pager: I/O error - pageout failed; blkno 20658,size 8192, error 12
swap_pager: I/O error - pageout failed; blkno 20746,size 8192, error 12
swap_pager: I/O error - pageout failed; blkno 31168,size 65536, error 12
swap_pager: I/O error - pageout failed; blkno 17793,size 4096, error 12
swap_pager: I/O error - pageout failed; blkno 31280,size 65536, error 12
swap_pager: indefinite wait buffer: device: ad2s1d.bde, blkno: 18517, size: 4096
Habe den fehler auf 2 Verschidenen rechner in Jails, wo kommt der fehler her? (platten und speicher sind 100% ok)
a) Kauf Dir ne neue Platte
b) Bevor Du a) machst, überprüfe sämtliche Kabel (auch Strom) der Platte
