current
BSD Fan
Wie Greg Lewis mitteilt, ist das Patchset 4 für das Java 1.4 SDK jetzt veröffentlicht. Aus seiner mail:
I am very pleased to finally be able to announce 1.4.1 patchset 4.
This patchset should be suitable for most applications, although it does
still contain a few problems. Use in a production environment is at
your own risk.
Some highlights of this release are:
1. Many bug fixes and code clean ups.
2. NetBSD support.
3. Browser plugin support.
4. GCC 3.3 support.
This one _should_ compile with the updated port on -CURRENT. Please give
it a try.
Thanks again to all the hard work by the BSD Java Porting Team and to the
FreeBSD Foundation for their continued support.
The patchset can, as usual, be downloaded from
http://www.eyesbeyond.com/freebsddom/java/jdk14.html
