kbtv und PyKDE
mario88
FREEAAK
Habe mir die saa-Treiber fuer meine TV-Karte installiert und wollte diese jetzt mit kbtv testen. Nur leider laesst sich der kbtv-Port nicht installieren. Folgende Fehlermeldung:
[root@workstation /usr/ports]# portinstall kbtv
[Gathering depends for multimedia/kbtv ................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................ done]
--->  Installing 'kbtv-1.2.4_1' from a port (multimedia/kbtv)
--->  Building '/usr/ports/multimedia/kbtv'
===>  Cleaning for kbtv-1.2.4_1
===>  Vulnerability check disabled, database not found
===>  Found saved configuration for kbtv-1.1.3
===>  Extracting for kbtv-1.2.4_1
=> MD5 Checksum OK for kbtv-1.2.4.tbz.
=> SHA256 Checksum OK for kbtv-1.2.4.tbz.
===>  Patching for kbtv-1.2.4_1
===>   kbtv-1.2.4_1 depends on executable: swig1.3 - found
===>   kbtv-1.2.4_1 depends on executable: kdepyuic - found
===>   kbtv-1.2.4_1 depends on file: /usr/local/bin/python2.5 - found
===>   kbtv-1.2.4_1 depends on file: /usr/local/bin/moc - found
===>   kbtv-1.2.4_1 depends on file: /usr/local/bin/sdl-config - found
===>   kbtv-1.2.4_1 depends on shared library: kimproxy - found
===>   kbtv-1.2.4_1 depends on shared library: SDL.11 - found
===>  Configuring for kbtv-1.2.4_1
Platform is freebsd6
Got Python 2.5.1
Got Gcc version 3.4.6 [freebsd] 20060305
Got Patch version 2.1
Got /usr/bin/make
Got swig 1.3.31
Got SDL 1.2.11
Got kernel source tree
Got PyQt for Qt 3.3.8
PyKDE kdecore import failed. Stop.
*** Error code 1
Stop in /usr/ports/multimedia/kbtv/work/kbtv-1.2.4.
*** Error code 1
Stop in /usr/ports/multimedia/kbtv.
*** Error code 1
** Command failed [exit code 1]: /usr/bin/script -qa /tmp/portinstall.7263.0 env make
** Fix the problem and try again.
** Listing the failed packages (*:skipped / !:failed)
        ! multimedia/kbtv       (unknown build error)
--->  Packages processed: 0 done, 0 ignored, 0 skipped and 1 failed
Leider finde ich im Internet nichts ueber diesen Fehler und ich muss zugeben ich habe eigentlich von python im Allgemeinen und von PyKDE im Besonderen ueberhaupt keine Ahnung.
Vielleicht hat jemand einen Rat fuer mich.
Danke im voraus
Problem ist gelöst!
py24-kde war zwar aus den Ports installiert, aber anscheinend irgendwie kaputt, hab jetzt py25-kde installiert, python24 deinstalliert und kbtv ließ sich übersetzen.
