Copyright (c) 1992-2005 The FreeBSD Project.
FreeBSD 5.4-STABLE #0: Tue May 10 23:41:10 CEST 2005
olly@tuxi.tibet.serveftp.net:/usr/obj/usr/src/sys/TUXI050405
CPU: AMD Athlon(tm) XP 2600+ (1921.04-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x6a0 Stepping = 0
Features=0x383fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE>
AMD Features=0xc0400000<AMIE,DSP,3DNow!>
real memory = 1073676288 (1023 MB)
avail memory = 1037209600 (989 MB)
mptable_probe: Unable to map end of MP Config Table
ACPI APIC Table: <Nvidia AWRDACPI>
ioapic0 <Version 1.1> irqs 0-23 on motherboard
npx0: INT 16 interface
acpi0: <Nvidia AWRDACPI> on motherboard
acpi0: Power Button (fixed)
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
cpu0: <ACPI CPU> on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: <memory, RAM> at device 0.1 (no driver attached)
pci0: <memory, RAM> at device 0.2 (no driver attached)
pci0: <memory, RAM> at device 0.3 (no driver attached)
pci0: <memory, RAM> at device 0.4 (no driver attached)
pci0: <memory, RAM> at device 0.5 (no driver attached)
isab0: <PCI-ISA bridge> at device 1.0 on pci0
isa0: <ISA bus> on isab0
pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
ohci0: <OHCI (generic) USB controller> mem 0xe0000000-0xe0000fff irq 22 at device 2.0 on pci0
usb0: <OHCI (generic) USB controller> on ohci0
usb0: USB revision 1.0
uhub0: nVidia OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub0: 3 ports with 3 removable, self powered
ohci1: <OHCI (generic) USB controller> mem 0xe0003000-0xe0003fff irq 21 at device 2.1 on pci0
usb1: OHCI version 1.0, legacy support
usb1: <OHCI (generic) USB controller> on ohci1
usb1: USB revision 1.0
uhub1: nVidia OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub1: 3 ports with 3 removable, self powered
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xe0004000-0xe00040ff irq 20 at device 2.2 on pci0
usb2: EHCI version 1.0
usb2: companion controllers, 4 ports each: usb0 usb1
usb2: <EHCI (generic) USB 2.0 controller> on ehci0
usb2: USB revision 2.0
uhub2: nVidia EHCI root hub, class 9/0, rev 2.00/1.00, addr 1
uhub2: 6 ports with 6 removable, self powered
pcib1: <ACPI PCI-PCI bridge> at device 8.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pci1: <multimedia, audio> at device 7.0 (no driver attached)
pci1: <input device> at device 7.1 (no driver attached)
xl0: <3Com 3c905B-TX Fast Etherlink XL> port 0xd800-0xd87f mem 0xdf801000-0xdf80107f irq 17 at device 9.0 on pci1
miibus0: <MII bus> on xl0
xlphy0: <3Com internal media interface> on miibus0
xlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
xl0: Ethernet address: 00:01:02:f5:04:d9
twe0: <3ware Storage Controller. Driver version 1.50.01.002> port 0xdc00-0xdc0f mem 0xdf000000-0xdf7fffff irq 16 at device 10.0 on pci1
twe0: 2 ports, Firmware FE7X 1.05.00.056, BIOS BE7X 1.08.00.046
atapci0: <nVidia nForce2 UDMA133 controller> port 0xf000-0xf00f,0x376,0x170-0x177,0x3f6,0x1f0-0x1f7 at device 9.0 on pci0
ata0: channel #0 on atapci0
ata1: channel #1 on atapci0
fwohci0: <1394 Open Host Controller Interface> mem 0xe0002000-0xe000203f,0xe0001000-0xe00017ff irq 22 at device 13.0 on pci0
fwohci0: OHCI version 1.10 (ROM=0)
fwohci0: No. of Isochronous channels is 4.
fwohci0: EUI64 00:e0:18:00:00:3f:81:54
fwohci0: Phy 1394a available S400, 2 ports.
fwohci0: Initiate bus reset
fwohci0: node_id=0xc800ffc1, gen=1, CYCLEMASTER mode
firewire0: 2 nodes, maxhop <= 1, cable IRM = 1 (me)
firewire0: bus manager 1 (me)
pcib2: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci2: <ACPI PCI bus> on pcib2
nvidia0: <GeForce FX 5200> mem 0xd0000000-0xd7ffffff,0xdc000000-0xdcffffff irq 19 at device 0.0 on pci2
fdc0: <floppy drive controller> port 0x3f7,0x3f0-0x3f5 irq 6 drq 2 on acpi0
ppc0: <ECP parallel printer port> port 0x778-0x77b,0x378-0x37f irq 7 drq 3 on acpi0
ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
ppc0: FIFO with 16/16/16 bytes threshold
ppbus0: IEEE1284 device found /NIBBLE/ECP
Probing for PnP devices on ppbus0:
ppbus0: <hp deskjet 5550> PRINTER MLC,PCL,PML,DW-PCL,DYN,DESKJET
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
kbd0 at atkbd0
psm0: model MouseMan+, device ID 0
orm0: <ISA Option ROMs> at iomem 0xd0000-0xd0fff,0xc0000-0xcf7ff on isa0
Timecounter "TSC" frequency 1921035521 Hz quality 800
ad0: 78533MB <IC35L080AVVA07-0/VA4OA52A> [159560/16/63] at ata0-master UDMA100
ad1: 78533MB <IC35L080AVVA07-0/VA4OA52A> [159560/16/63] at ata0-slave UDMA100
acd0: DVDROM <TOSHIBA DVD-ROM SD-M1502/1012> at ata1-master PIO4
acd1: DVDR <PIONEER DVD-RW DVR-105/1.33> at ata1-slave PIO4
twed0: <Unit 0, RAID0, Normal> on twe0
twed0: 381562MB (781439744 sectors)
firewire0: New S400 device ID:000a270002d8997b
da0 at sbp0 bus 0 target 0 lun 0
da0: <Apple Co iPod 2700> Removable Simplified Direct Access SCSI-0 device
da0: 50.000MB/s transfers
da0: 38147MB (78126048 512 byte sectors: 255H 63S/T 4863C)
cd0 at ata1 bus 0 target 0 lun 0
cd0: <TOSHIBA DVD-ROM SD-M1502 1012> Removable CD-ROM SCSI-0 device
cd0: 16.000MB/s transfers
cd0: Attempt to query device size failed: NOT READY, Medium not present
cd1 at ata1 bus 0 target 1 lun 0
cd1: <PIONEER DVD-RW DVR-105 1.33> Removable CD-ROM SCSI-0 device
cd1: 16.000MB/s transfers
cd1: Attempt to query device size failed: NOT READY, Medium not present
Mounting root from ufs:/dev/ad0s1a
WARNING: driver "vmmon" used unreserved major device number 200
vmmon: Module vmmon: registered with major=200 minor=0 tag=$Name: build-570 (3.2.x mvm) $
vmmon: Module vmmon: initialized
WARNING: /mnt was not properly dismounted
fwohci0: BUS reset
fwohci0: node_id=0xc800ffc0, gen=2, CYCLEMASTER mode
firewire0: bus manager 0 (me)
