kein Sound
kmh
Hiho,
so ich bin inzwischen etwas ratlos, ich habe fast saemtliche Eintraeg zum Thema "kein Sound" in diesem Forum und anderen Orts gelesen. Es hat leider keine Abhilfe gebracht.
dmesg:
OpenBSD 4.0 (GENERIC) #1107: Sat Sep 16 19:15:58 MDT 2006
    deraadt@i386.openbsd.org:/usr/src/sys/arch/i386/compile/GENERIC
cpu0: AMD Athlon(TM) XP 1800+ ("AuthenticAMD" 686-class, 256KB L2 cache) 1.16 GHz
cpu0: FPU,V86,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE
real mem  = 804847616 (785984K)
avail mem = 725676032 (708668K)
using 4256 buffers containing 40345600 bytes (39400K) of memory
mainbus0 (root)
bios0 at mainbus0: AT/286+(5a) BIOS, date 12/14/04, BIOS32 rev. 0 @ 0xf1940, SMBIOS rev. 2.3 @ 0xf38a0 (53 entries)
bios0: ASUSTeK Computer INC. A7V600-X
apm0 at bios0: Power Management spec V1.2
apm0: AC on, battery charge unknown
apm0: flags 30102 dobusy 0 doidle 1
pcibios0 at bios0: rev 2.1 @ 0xf0000/0x1ff2
pcibios0: PCI IRQ Routing Table rev 1.0 @ 0xf1f20/208 (11 entries)
pcibios0: PCI Interrupt Router at 000:17:0 ("VIA VT82C586 ISA" rev 0x00)
pcibios0: PCI bus #1 is the last bus
bios0: ROM list: 0xc0000/0xf800 0xd0000/0x4400!
cpu0 at mainbus0
pci0 at mainbus0 bus 0: configuration mode 1 (no bios)
pchb0 at pci0 dev 0 function 0 "VIA VT8377 PCI" rev 0x80
ppb0 at pci0 dev 1 function 0 "VIA VT8377 AGP" rev 0x00
pci1 at ppb0 bus 1
vga1 at pci1 dev 0 function 0 "NVIDIA GeForce FX 5200" rev 0xa1
wsdisplay0 at vga1 mux 1: console (80x25, vt100 emulation)
bktr0 at pci0 dev 10 function 0 "Brooktree BT878" rev 0x11pci_intr_map: no mapping for pin A
bktr0: couldn't map interrupt
"Brooktree BT878 Audio" rev 0x11 at pci0 dev 10 function 1 not configured
pciide0 at pci0 dev 15 function 0 "VIA VT6420 SATA" rev 0x80: DMA
pciide0: using irq 9 for native-PCI interrupt
wd0 at pciide0 channel 0 drive 0: <WDC WD1200JS-55MHB0>
wd0: 16-sector PIO, LBA48, 114473MB, 234441648 sectors
wd0(pciide0:0:0): using PIO mode 4, Ultra-DMA mode 5
pciide1 at pci0 dev 15 function 1 "VIA VT82C571 IDE" rev 0x06: ATA133, channel 0 configured to compatibility, channel 1 configured to compatibility
pciide1: channel 0 disabled (no drives)
atapiscsi0 at pciide1 channel 1 drive 0
scsibus0 at atapiscsi0: 2 targets
cd0 at scsibus0 targ 0 lun 0: <TEAC, DV-W50D, 1.06> SCSI0 5/cdrom removable
cd0(pciide1:1:0): using PIO mode 4, Ultra-DMA mode 2
uhci0 at pci0 dev 16 function 0 "VIA VT83C572 USB" rev 0x81: irq 5
usb0 at uhci0: USB revision 1.0
uhub0 at usb0
uhub0: VIA UHCI root hub, rev 1.00/1.00, addr 1
uhci1 at pci0 dev 16 function 1 "VIA VT83C572 USB" rev 0x81: irq 5
usb1 at uhci1: USB revision 1.0
uhub1 at usb1
uhub1: VIA UHCI root hub, rev 1.00/1.00, addr 1
uhci2 at pci0 dev 16 function 2 "VIA VT83C572 USB" rev 0x81: irq 9
usb2 at uhci2: USB revision 1.0
uhub2 at usb2
uhub2: VIA UHCI root hub, rev 1.00/1.00, addr 1
uhci3 at pci0 dev 16 function 3 "VIA VT83C572 USB" rev 0x81: irq 9
usb3 at uhci3: USB revision 1.0
uhub3 at usb3
uhub3: VIA UHCI root hub, rev 1.00/1.00, addr 1
uhub3: 2 ports with 2 removable, self powered
ehci0 at pci0 dev 16 function 4 "VIA VT6202 USB" rev 0x86: irq 11
usb4 at ehci0: USB revision 2.0
uhub4 at usb4
uhub4: VIA EHCI root hub, rev 2.00/1.00, addr 1
uhub4: 8 ports with 8 removable, self powered
viapm0 at pci0 dev 17 function 0 "VIA VT8237 ISA" rev 0x00
iic0 at viapm0
"unknown" at iic0 addr 0x18 not configured
auvia0 at pci0 dev 17 function 5 "VIA VT8233 AC97" rev 0x60: irq 11
ac97: codec id 0x41445370 (Analog Devices AD1980)
ac97: codec features headphone, 20 bit DAC, No 3D Stereo
audio0 at auvia0
vr0 at pci0 dev 18 function 0 "VIA RhineII-2" rev 0x78: irq 5, address 00:0e:a6:03:66:95
rlphy0 at vr0 phy 1: RTL8201L 10/100 PHY, rev. 1
ath0 at pci0 dev 19 function 0 "Atheros AR5212" rev 0x01pci_intr_map: no mapping for pin A
isa0 at mainbus0
isadma0 at isa0
pckbc0 at isa0 port 0x60/5
pckbd0 at pckbc0 (kbd slot)
wskbd0 at pckbd0: console keyboard, using wsdisplay0
pmsi0 at pckbc0 (aux slot)
pckbc0: using irq 12 for aux slot
wsmouse0 at pmsi0 mux 0
pcppi0 at isa0 port 0x61
midi0 at pcppi0: <PC speaker>
spkr0 at pcppi0
lpt0 at isa0 port 0x378/4 irq 7
it0 at isa0 port 0x290/8: IT87
npx0 at isa0 port 0xf0/16: using exception 16
pccom0 at isa0 port 0x3f8/8 irq 4: ns16550a, 16 byte fifo
fdc0 at isa0 port 0x3f0/6 irq 6 drq 2
fd0 at fdc0 drive 0: 1.44MB 80 cyl, 2 head, 18 sec
biomask ef6d netmask ef6d ttymask ffef
pctr: user-level cycle counter enabled
mtrr: Pentium Pro MTRR support
dkcsum: wd0 matches BIOS drive 0x80
root on wd0a
rootdev=0x0 rrootdev=0x300 rawdev=0x302
Hier die Mixerctl ausgabe:
outputs.master=207,207
outputs.master.mute=off
outputs.mono=255
outputs.mono.mute=off
outputs.mono.source=mixerout
outputs.headphones=163,163
outputs.headphones.mute=off
outputs.bass=255
outputs.treble=255
inputs.speaker=255
inputs.speaker.mute=off
inputs.phone=191
inputs.phone.mute=on
inputs.mic=191
inputs.mic.mute=on
inputs.mic.preamp=off
inputs.mic.source=mic0
inputs.line=191,191
inputs.line.mute=on
inputs.cd=191,191
inputs.cd.mute=off
inputs.video=255,255
inputs.video.mute=off
inputs.aux=191,191
inputs.aux.mute=off
inputs.dac=191,191
inputs.dac.mute=off
record.source=mic
record.volume=255,255
record.volume.mute=off
record.mic=0
record.mic.mute=off
outputs.loudness=off
outputs.spatial=off
outputs.spatial.center=0
outputs.spatial.depth=0
outputs.surround=255,255
outputs.surround.mute=off
outputs.center=255
outputs.center.mute=off
outputs.lfe=255
outputs.lfe.mute=off
outputs.extamp=off
Irgendwie sehe ich den Fehler nicht. Der Sound-Chip wird auch von OpenBSD unterstuetzt. Woran kann es noch liegen?
Alles richtig angeschlossen hast du? Nichts im Bios "Verfriemelt" oder so? Nicht mehrere Soundkarten eingebaut (z.B. eine "normale" und eine "onboard?")
Kommt von den jeweiligen Programmen eine Fehlermeldung? (Kann Device nicht öffnen oder so?)
Kannst du direkt eine Sound-Datei auf die Geräteschnittstelle ausgeben?
Ich hatte zeitweise noch eine 2te Soundkarte eingebaut. Diese habe ich zwecks Fehlerbehebung entfernt. Im Bios steht die OnBoard-Sound-Karte auf [auto], die andere Moeglichkeit waere [Off] ;) . Ich habe sowohl per
cat blablub.mp3 > /dev/audio
wie auch mit
mpg123 blablub.mp3
versucht der Soundkarte einen Ton zu entlocken. Dann dachte ich daran das es doch ggf. auch daran liegen koennte das ein Kabel locker sitzt etc....Unter Linux ist der Sound Kristallklar :confused:
$ mixerctl -a | grep mute
inputs.phone.mute=off
inputs.mic.mute=off
inputs.line.mute=off
inputs.cd.mute=off
inputs.aux.mute=off
inputs.dac.mute=off
record.mic.mute=off
Nichts zu hoeren....
Nein, es kommt kein Fehler.
Hmm ... ich hatte/hab es, bei einem PC, das die Onboard-Soundkarte, einfach nicht unter OpenBSD funktiont hat, bei allen anderen Betriebsystemen schon.
Angeblich wurde alles erkannt und der selbe chip, auf einem anderen Mainboard eines anderen Herstellers funktionierte unter OpenBSD problemlos.
Da ich keine lust auf große Fehlersuche hatte, hab ich einfach den Onboard deaktiviert und ne zusätzliche Karte reingepackt, die in einem anderen PC unter OpenBSD ohne probleme funktioniert hat.
setz mal folgendes auf on von deinen obigen einstellungen ausgehend:
outputs.mono.mute=on
inputs.cd.mute=on
inputs.video.mute=on
inputs.aux.mute=on
outputs.surround.mute=on
outputs.center.mute=on
outputs.lfe.mute=on
@CommanderZed:
Tja, das wuerde ich ja glatt machen. Waere meine Soundkarte die ich ausgebaut habe nicht ein "Soundblaster Live! 24Bit" die nicht unterstuetzt wird(afaik) :(
Extra eine neue Soundkarte kaufen wollte ich eigentlich nicht. Auch wenn es diese recht guenstig bei eBay gibt.
@r2d2:
Habe ich gemacht, aber ich verstehe nicht so ganz was du damit bezwecken moechtest?
Ich moechte doch eigentlich das mute=off ist?!
[Edit]
ok....es hat doch geholfen...oder doch nicht? Ich bin nun voellig verwirrt, die Ausgabe erfolgt nun ueber meinen Mikrofon Eingang( Hat die Farbe Rot steht so auch im Handbuch meines Mainboards). Wie bekomme ich die Ausgabe jetzt wieder auf meinen "normalen" Ausgang?
Danke fuer eure Muehe!
