C
CrimsonKing
Mhm, gut, danke. Damit verwerfe ich diesen Plan wieder.
- r262693: Fix a file descriptor leak. In praxis this is very hard
to trigger, especially on low performance machines like
the APU. Nevertheless apply the fix while here.
- r263022: Be compatible with BIOSes that incorrectly use standard
memory resource ranges to decode the memory ranges of PCI
devices. The underlying issue was solved with PC Engines
APU BIOS revision 04/01/14, nevertheless apply the fix to
be sure.
- r264442: Increase TSO segment count in several drivers from 32 to 35.
This greatly helps NFS performance, since 32 segments aren't
enough to support a full NFS payload.
- r265414: Reduce the number of payload segments generated by the NFS
server. In addition to r264442 this greatly increases NFS
performance on TSO enabled NICs.
Nein Yamagi meint dieses Teil hier [1]4 GB? Das ist dann kein RPi mehr, oder?![]()
