lars
vom mars
Hi all,
OS:
OBSD 3.3 CD-Version
Hardware:
IBM Thinkpad R40
u.a.
Intel Pro/100 VE
Problem:
#dmesg
"Intel PRO/100 VE" rev 0x83 at pci dev 8 function 0 not configured
1-----------------------------------------------------------------
Ich habe mit
#config -e -o /bsd.test /bsd
versucht die Karte und den Treiber zur Kooperation
zu bewegen indem ich
ukc>change 69
dev[8]
function[1]
flags[0]
gesetzt habe, weil dmesg die NIC so gefunden hat:
"Intel PRO/100 VE" rev 0x83 at pci 2 dev 8 function 0 not configured
2-----------------------------------------------------------------
nach einem Google:
Hello,
received my IBM ThinkPad R40 and it seems to have some new circuits that OpeBSD dosen't recognize with the 2003-03-29 snapshot.
With this change the fxp is recognize and works well enough to transfer a complete snapshots/i386 directory over FTP.
cvs server: Diffing .
Index: if_fxp_pci.c
RCS file: /cvs/src/sys/dev/pci/if_fxp_pci.c,v
retrieving revision 1.18
diff -u -r1.18 if_fxp_pci.c
--- if_fxp_pci.c 2003/02/18 01:31:45 1.18
+++ if_fxp_pci.c 2003/04/11 19:28:09
-95,6 +95,7
{ PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VE_1 },
{ PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VE_2 },
{ PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VE_3 },
+ { PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VE_4 },
{ PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VM_0 },
{ PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VM_1 },
{ PCI_VENDOR_INTEL, PCI_PRODUCT_INTEL_PRO_100_VM_2 },
I didn't want to play with the pciide (or the other stuff), but I will gladly test patches.
Mach ich in Teil 1 was fasch oder ist die Lösung in Teil 2,
wenn T2, wie kann ich das umsetzen, ich weiss nicht,
was damit gemeint ist?
Many TIA,
Lars.
OS:
OBSD 3.3 CD-Version
Hardware:
IBM Thinkpad R40
u.a.
Intel Pro/100 VE
Problem:
#dmesg
Ich habe mit
ukc>change 69
dev[8]
function[1]
flags[0]
nach einem Google:
Hello,
Index: if_fxp_pci.c
-95,6 +95,7
Many TIA,
Lars.
