portupgrade: at-spi und gnome-pkgview wollen nicht
nihonto
Hallo Forum,
habe gestern Abend mal wieder ein portupgrade gemacht. Das Paket "at-spi" will aber nicht so recht.
Nach "cvsup -g -L 2 ports-supfile", einem anschließenden "portsdb -Uu" und dem "portupgrade -arR" endete das Update für gnome-pkgview mit folgender Meldung:
gmake[2]: Entering directory `/usr/ports/sysutils/gnome-pkgview/work/gnome-pkgview-1.0.4'
LC_ALL=C ./intltool-merge ./po gnome-pkgview.desktop.in gnome-pkgview.desktop -d -u -c ./po/.intltool-merge-cache
Not enough arguments for mkdir at ./intltool-merge line 870, near "$lang or"
Execution of ./intltool-merge aborted due to compilation errors.
gmake[2]: *** [gnome-pkgview.desktop] Fehler 255
gmake[2]: Leaving directory `/usr/ports/sysutils/gnome-pkgview/work/gnome-pkgview-1.0.4'
gmake[1]: *** [all-recursive] Fehler 1
gmake[1]: Leaving directory `/usr/ports/sysutils/gnome-pkgview/work/gnome-pkgview-1.0.4'
gmake: *** [all-recursive-am] Fehler 2
*** Error code 2
Stop in /usr/ports/sysutils/gnome-pkgview.
** Command failed [exit code 1]: /usr/bin/script -qa /tmp/portupgrade300.22 make** Fix the problem and try again.
---> Skipping 'x11-toolkits/libgail-gnome' (libgail-gnome-1.0.2_2) because 'x11-toolkits/at-spi' (at-spi-1.3.8) failed
---> Skipping 'sysutils/gok' (gok-0.8.4) because 'x11-toolkits/at-spi' (at-spi-1.3.8) failed
** The following packages were not installed or upgraded (*:skipped / !:failed)
! x11-toolkits/at-spi (at-spi-1.3.8) (unknown build error)
! sysutils/gnome-pkgview (gnome-pkgview-1.0.2) (unknown build error)
* x11-toolkits/libgail-gnome (libgail-gnome-1.0.2_2)
* sysutils/gok (gok-0.8.4)
Vorher ist schon die Installation von at-spi gescheitert:
gmake[2]: Entering directory `/usr/ports/x11-toolkits/at-spi/work/at-spi-1.3.9/registryd'
LC_ALL=C ../intltool-merge ../po Accessibility_Registry.server.in Accessibility_Registry.server -o -u -c ../po/.intltool-merge-cache
Not enough arguments for mkdir at ../intltool-merge line 861, near "$lang or"
Execution of ../intltool-merge aborted due to compilation errors.
gmake[2]: *** [Accessibility_Registry.server] Fehler 255
gmake[2]: Leaving directory `/usr/ports/x11-toolkits/at-spi/work/at-spi-1.3.9/registryd'
gmake[1]: Leaving directory `/usr/ports/x11-toolkits/at-spi/work/at-spi-1.3.9'
*** Error code 2
Stop in /usr/ports/x11-toolkits/at-spi.
** Command failed [exit code 1]: /usr/bin/script -qa /tmp/portupgrade300.16 make** Fix the problem and try again.
Habe mal die Passagen gefettet, die mir am interessantesten erschienen. Leider kann ich mit den Ausagen aber nix anfangen;-).
Jemand eine Idee, was da falsch läuft?
Hi current,
danke für die Antwort. Scheint aber nicht zu funktionieren. Nach dem Port-Update und portsdb -Uu kommt bei Eingabe von "portversion -l "<"" nur folgende Antwort:
Stale dependency: libgail-gnome-1.0.2_2 --> at-spi-1.3.8 -- manually run 'pkgdb-F' to fix, or specify -O to force.
pkgdb -F will aber gleich ein paar hundert neue dependencies setzen. Das kann's ja wohl auch nicht sein. portupgrade funzt natürlich auch nicht.
Jemand eine Idee, wie das Schlamassel gelöst werden könnte?
Aaargh, hatte vergessen das "work"-directory aus dem "at-spi"-port zu löschen. Das konnte ja nicht funktionieren. Hab's jetzt nachgeholt. Das Portupgrade ist nun glatt durchgelaufen:-)!!!
