[Problem] 3D-Unterstützung mit R9250 unter FBSD
Ich habe jetzt das System auf 7.0-STABLE aktualisiert, aber es geht immer noch nicht. :(
edit: Hier meine Xorg log
X.Org X Server 1.4.0
Release Date: 5 September 2007
Build Operating System: FreeBSD 7.0-RELEASE i386
Current Operating System: FreeBSD localhost 7.0-STABLE FreeBSD 7.0-STABLE #1: Fri Jul  4 12:53:42 UTC 2008     user@localhost:/usr/obj/usr/src/sys/MYKERNEL i386
Build Date: 01 May 2008  03:03:28PM
	Before reporting problems, check http://wiki.x.org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul  4 17:04:01 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Option "AIGLX" "True"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) Including the default font path /usr/local/lib/X11/fonts/misc/,/usr/local/lib/X11/fonts/TTF/,/usr/local/lib/X11/fonts/OTF,/usr/local/lib/X11/fonts/Type1/,/usr/local/lib/X11/fonts/100dpi/,/usr/local/lib/X11/fonts/75dpi/.
(**) FontPath set to:
	/usr/local/lib/X11/fonts/75dpi/,
(**) RgbPath set to "/usr/local/share/X11/rgb"
(**) ModulePath set to "/usr/local/lib/xorg/modules"
(**) Extension "Composite" is enabled
(II) Loader magic: 0x81ce4e0
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 2.0
	X.Org XInput driver : 2.0
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on freebsd
(II) LoadModule: "pcidata"
(II) Loading /usr/local/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 1.0.0
	ABI class: X.Org Video Driver, version 2.0
(--) Using syscons driver with X support (version 2.0)
(--) using VT number 9
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000cf8, mode1Res1 = 0x00000cf8
(WW) OS did not count PCI devices, guessing wildly
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1039,0740 card 0000,0000 rev 01 class 06,00,00 hdr 80
(II) PCI: 00:01:0: chip 1039,0001 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 1039,0008 card 0000,0000 rev 25 class 06,01,00 hdr 80
(II) PCI: 00:02:5: chip 1039,5513 card 0000,0000 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:02:7: chip 1039,7012 card 13f6,0300 rev a0 class 04,01,00 hdr 00
(II) PCI: 00:03:0: chip 1039,7001 card 1462,5470 rev 0f class 0c,03,10 hdr 80
(II) PCI: 00:03:1: chip 1039,7001 card 1462,5470 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:3: chip 1039,7002 card 1462,5470 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:04:0: chip 1039,0900 card 1039,0900 rev 90 class 02,00,00 hdr 00
(II) PCI: 00:09:0: chip 1002,5960 card 174b,0250 rev 01 class 03,00,00 hdr 80
(II) PCI: 00:09:1: chip 1002,5940 card 174b,0251 rev 01 class 03,80,00 hdr 00
(II) PCI: 01:00:0: chip 1039,6325 card 1039,6325 rev 00 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 1 I/O range:
	[0] -1	0	0x0000a000 - 0x0000afff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xcfd00000 - 0xcfefffff (0x200000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0x9fa00000 - 0xafbfffff (0x10200000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:2:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(0:9:0) ATI Technologies Inc RV280 [Radeon 9200 PRO] rev 1, Mem @ 0xc0000000/27, 0xcfff0000/16, I/O @ 0xd800/8, BIOS @ 0xcffc0000/17
(--) PCI: (0:9:1) ATI Technologies Inc RV280 [Radeon 9200 PRO] (Secondary) rev 1, Mem @ 0xb8000000/27, 0xcff90000/16
(--) PCI: (1:0:0) Silicon Integrated Systems [SiS] 65x/M650/740 PCI/AGP VGA Display Adapter rev 0, Mem @ 0xa0000000/27, 0xcfee0000/17, I/O @ 0xac00/7
(II) Addressable bus resource ranges are
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd0000000 from 0xdfffffff to 0xcfffffff
(II) Active PCI resource ranges:
	[0] -1	0	0xcffec000 - 0xcffeffff (0x4000) MX[B]E
	[1] -1	0	0xcffef000 - 0xcffeffff (0x1000) MX[B]E
	[2] -1	0	0xcffee000 - 0xcffeffff (0x2000) MX[B]E
	[3] -1	0	0xcffed000 - 0xcffedfff (0x1000) MX[B]E
	[4] -1	0	0xd0000000 - 0xcfffffff (0x0) MX[B]EO
	[5] -1	0	0xcfee0000 - 0xcfefffff (0x20000) MX[B](B)
	[6] -1	0	0xa0000000 - 0xa7ffffff (0x8000000) MX[B](B)
	[7] -1	0	0xcff90000 - 0xcff9ffff (0x10000) MX[B](B)
	[8] -1	0	0xb8000000 - 0xbfffffff (0x8000000) MX[B](B)
	[9] -1	0	0xcffc0000 - 0xcffdffff (0x20000) MX[B](B)
	[10] -1	0	0xcfff0000 - 0xcfffffff (0x10000) MX[B](B)
	[11] -1	0	0xc0000000 - 0xc7ffffff (0x8000000) MX[B](B)
	[12] -1	0	0x0000d000 - 0x0000d0ff (0x100) IX[B]E
	[13] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[B]E
	[14] -1	0	0x0000dc00 - 0x0000dcff (0x100) IX[B]E
	[15] -1	0	0x0000ff00 - 0x0000ffff (0x100) IX[B]E
	[16] -1	0	0x0000ac00 - 0x0000ac7f (0x80) IX[B](B)
	[17] -1	0	0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
(II) PCI Memory resource overlap reduced 0xcffec000 from 0xcffeffff to 0xcffecfff
(II) PCI Memory resource overlap reduced 0xcffee000 from 0xcffeffff to 0xcffeefff
(II) Active PCI resource ranges after removing overlaps:
	[0] -1	0	0xcffec000 - 0xcffecfff (0x1000) MX[B]E
	[2] -1	0	0xcffee000 - 0xcffeefff (0x1000) MX[B]E
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xcffec000 - 0xcffecfff (0x1000) MX[B]E
	[5] -1	0	0xcffef000 - 0xcffeffff (0x1000) MX[B]E
	[6] -1	0	0xcffee000 - 0xcffeefff (0x1000) MX[B]E
	[7] -1	0	0xcffed000 - 0xcffedfff (0x1000) MX[B]E
	[8] -1	0	0xd0000000 - 0xcfffffff (0x0) MX[B]EO
	[9] -1	0	0xcfee0000 - 0xcfefffff (0x20000) MX[B](B)
	[10] -1	0	0xa0000000 - 0xa7ffffff (0x8000000) MX[B](B)
	[11] -1	0	0xcff90000 - 0xcff9ffff (0x10000) MX[B](B)
	[12] -1	0	0xb8000000 - 0xbfffffff (0x8000000) MX[B](B)
	[13] -1	0	0xcffc0000 - 0xcffdffff (0x20000) MX[B](B)
	[14] -1	0	0xcfff0000 - 0xcfffffff (0x10000) MX[B](B)
	[15] -1	0	0xc0000000 - 0xc7ffffff (0x8000000) MX[B](B)
	[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[17] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[18] -1	0	0x0000d000 - 0x0000d0ff (0x100) IX[B]E
	[19] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[B]E
	[20] -1	0	0x0000dc00 - 0x0000dcff (0x100) IX[B]E
	[21] -1	0	0x0000ff00 - 0x0000ffff (0x100) IX[B]E
	[22] -1	0	0x0000ac00 - 0x0000ac7f (0x80) IX[B](B)
	[23] -1	0	0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded. This was enabled by default and also specified in the config file.
(II) "type1" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dbe"
(II) Loading /usr/local/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
	Module class: X.Org Server Extension
	ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/local/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "record"
(II) Loading /usr/local/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "xtrap"
(II) Loading /usr/local/lib/xorg/modules/extensions//libxtrap.so
(II) Module xtrap: vendor="X.Org Foundation"
(II) Loading extension DEC-XTRAP
(II) LoadModule: "dri"
(II) Loading /usr/local/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "glx"
(II) Loading /usr/local/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(**) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/local/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
	compiled for 1.4.0, module version = 2.1.0
	Module class: X.Org Font Renderer
	ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/local/lib/xorg/modules/fonts//libtype1.so
(II) Module type1: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "radeon"
(II) Loading /usr/local/lib/xorg/modules/drivers//radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 4.3.0
	Module class: X.Org Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/local/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 1.2.3
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/local/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 1.2.2
(II) RADEON: Driver for ATI Radeon chipsets:
	ATI Radeon Mobility X600 (M24) 3150 (PCIE),
	ATI Radeon Mobility X300 (M24) 3152 (PCIE),
	ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X600 (RV380) 3E50 (PCIE),
	ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
	ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
	ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
	ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
	ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
	ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
	ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
	ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
	ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
	ATI Radeon 8500 AIW BB (AGP), ATI Radeon 8500 AIW BC (AGP),
	ATI Radeon IGP320M (U1) 4336, ATI Radeon IGP330M/340M/350M (U2) 4337,
	ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
	ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
	ATI Radeon X800PRO (R420) JI (AGP),
	ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
	ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
	ATI Radeon Mobility 9800 (M18) JN (AGP),
	ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
	ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
	ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
	ATI Radeon Mobility M7 LW (AGP),
	ATI Mobility FireGL 7800 M7 LX (AGP),
	ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
	ATI FireGL Mobility 9000 (M9) Ld (AGP),
	ATI Radeon Mobility 9000 (M9) Lf (AGP),
	ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
	ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
	ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
	ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
	ATI Radeon 9800XT NJ (AGP),
	ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
	ATI Radeon Mobility 9600 (M10) NQ (AGP),
	ATI Radeon Mobility 9600 (M11) NR (AGP),
	ATI Radeon Mobility 9600 (M10) NS (AGP),
	ATI FireGL Mobility T2 (M10) NT (AGP),
	ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
	ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
	ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
	ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
	ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
	ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
	ATI Radeon Mobility X300 (M22) 5460 (PCIE),
	ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
	ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
	ATI Radeon X800PRO (R423) UI (PCIE),
	ATI Radeon X800LE (R423) UJ (PCIE),
	ATI Radeon X800SE (R423) UK (PCIE),
	ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
	ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
	ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
	ATI FireGL unknown (R423) UR (PCIE),
	ATI FireGL unknown (R423) UT (PCIE),
	ATI Mobility FireGL V5000 (M26) (PCIE),
	ATI Mobility Radeon X700 XL (M26) (PCIE),
	ATI Mobility Radeon X700 (M26) (PCIE),
	ATI Mobility Radeon X700 (M26) (PCIE), ATI Radeon 9100 IGP (A5) 5834,
	ATI Radeon Mobility 9100 IGP (U3) 5835,
	ATI Radeon XPRESS 200 5954 (PCIE),
	ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
	ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
	ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
	ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
	ATI Radeon XPRESS 200M 5975 (PCIE),
	ATI Radeon XPRESS 200 5A41 (PCIE),
	ATI Radeon XPRESS 200M 5A42 (PCIE),
	ATI Radeon XPRESS 200 5A61 (PCIE),
	ATI Radeon XPRESS 200M 5A62 (PCIE),
	ATI Radeon X300 (RV370) 5B60 (PCIE),
	ATI Radeon X600 (RV370) 5B62 (PCIE),
	ATI Radeon X550 (RV370) 5B63 (PCIE),
	ATI Radeon X550XTX (RV370) 5657 (PCIE),
	ATI FireGL V3100 (RV370) 5B64 (PCIE),
	ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
	ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
	ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
	ATI Mobility Radeon X800 XT (M28) (PCIE),
	ATI Mobility FireGL V5100 (M28) (PCIE),
	ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
	ATI Radeon X850 XT PE (R480) (PCIE),
	ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
	ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
	ATI Radeon X850 XT (R480) (PCIE),
	ATI Radeon X800XT (R423) 5D57 (PCIE),
	ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
	ATI Radeon X700 PRO (RV410) (PCIE),
	ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
	ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
	ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
	ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
	ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
	ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
	ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
	ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
	ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
	ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
	ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
	ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
	ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
	ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
	ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
	ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
	ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
	ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
	ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
	ATI Mobility Radeon X1700, ATI  Radeon X2300HD,
	ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
	ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
	ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
	ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
	ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI ATI FireGL V7400,
	ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
	ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
	ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
	ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
	ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI RV610,
	ATI ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
	ATI Mobility Radeon HD 2400, ATI ATI RADEON E2400, ATI RV610,
	ATI RV670, ATI Radeon HD3870, ATI Radeon HD3850, ATI RV670,
	ATI Radeon HD3870 X2, ATI FireGL V7700, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI ATI Radeon HD 2600 XT AGP, ATI ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini ATI Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI ATI Radeon HD 2600 LE[COLOR="Silver"][B]
(II) Primary Device is: PCI 00:09:0
(WW) RADEON: No matching Device section for instance (BusID PCI:0:9:1) found[/B][/COLOR]
(--) Chipset ATI Radeon 9250 5960 (AGP) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
	[16] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
	[17] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
	[18] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
	[19] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[20] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[21] -1	0	0x0000d000 - 0x0000d0ff (0x100) IX[B]E
	[22] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[B]E
	[23] -1	0	0x0000dc00 - 0x0000dcff (0x100) IX[B]E
	[24] -1	0	0x0000ff00 - 0x0000ffff (0x100) IX[B]E
	[25] -1	0	0x0000ac00 - 0x0000ac7f (0x80) IX[B](B)
	[26] -1	0	0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
	[27] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
	[28] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) RADEON(0): MMIO registers at 0x00000000cfff0000: size 64KB
(==) RADEON(0): Write-combining range (0xcfff0000,0x10000) was already clear
(II) RADEON(0): PCI bus 0 card 9 func 0
(**) RADEON(0): Depth 24, (--) framebuffer bpp 32
(II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) RADEON(0): Default visual is TrueColor
(**) RADEON(0): Option "EnablePageFlip" "True"
(**) RADEON(0): Option "DRI" "On"
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/local/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 0.1.0
(II) RADEON(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(==) RADEON(0): RGB weight 888
(II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/local/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) RADEON(0): initializing int10
(==) RADEON(0): Write-combining range (0xa0000,0x20000) was already clear
(==) RADEON(0): Write-combining range (0xc0000,0x40000) was already clear
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(==) RADEON(0): Write-combining range (0x0,0x1000) was already clear
(--) RADEON(0): Chipset: "ATI Radeon 9250 5960 (AGP)" (ChipID = 0x5960)
(--) RADEON(0): Linear framebuffer at 0x00000000c0000000
(--) RADEON(0): BIOS at 0xcffc0000
(II) RADEON(0): PCI card detected
(II) RADEON(0): Legacy BIOS detected
[COLOR="Silver"][B]drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such file or directory)
drmOpenDevice: Open failed
[drm] failed to load kernel module "radeon"
(EE) RADEON(0): [dri] RADEONDRIGetVersion failed to open the DRM
[dri] Disabling DRI.[/B][/COLOR]
(II) RADEON(0): Generation 2 PCI interface, using max accessible memory
(II) RADEON(0): Detected total video RAM=131072K, accessible=131072K (PCI BAR=131072K)
(--) RADEON(0): Mapped VideoRAM: 131072 kByte (64 bit DDR SDRAM)
(II) RADEON(0): Color tiling enabled by default
(II) RADEON(0): Max desktop size set to 2048x1200
(II) RADEON(0): For a larger or smaller max desktop size, add a Virtual line to your xorg.conf
(II) RADEON(0): If you are having trouble with 3D, reduce the desktop size by adjusting the Virtual line to your xorg.conf
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) RADEON(0): ref_freq: 2700, min_out_pll: 20000, max_out_pll: 40000, min_in_pll: 40, max_in_pll: 3000, xclk: 20000, sclk: 200.000000, mclk: 240.000000
(II) RADEON(0): PLL parameters: rf=2700 rd=12 min=20000 max=40000; xclk=20000
(II) RADEON(0): Bios Connector table:
(II) RADEON(0): Port0: DDCType-0x60, DACType-1, TMDSType-1, ConnectorType-1
(II) RADEON(0): Port1: DDCType-0x64, DACType-2, TMDSType-1, ConnectorType-2
(II) RADEON(0): Port5: DDCType-0x0, DACType-2, TMDSType-0, ConnectorType-5
(II) RADEON(0): Output VGA-0 using monitor section Monitor0
(II) RADEON(0): I2C bus "VGA-0" initialized.
(II) RADEON(0): Output DVI-0 has no monitor section
(II) RADEON(0): DFP table revision: 4
(II) RADEON(0): I2C bus "DVI-0" initialized.
(II) RADEON(0): Output S-video has no monitor section
(II) RADEON(0): Default TV standard: PAL
(II) RADEON(0): TV standards supported by chip: NTSC PAL
 Monitor   -- AUTO
 Connector -- VGA
 DAC Type  -- Primary
 TMDS Type -- None
 DDC Type  -- 0x60
 Monitor   -- AUTO
 Connector -- DVI-I
 DAC Type  -- TVDAC/ExtDAC
 TMDS Type -- Internal
 DDC Type  -- 0x64
(II) RADEON(0): Port2:
 Monitor   -- AUTO
 Connector -- STV
 TMDS Type -- None
 DDC Type  -- 0x0
(II) RADEON(0): I2C device "VGA-0:ddc2" registered at address 0xA0.
(II) RADEON(0): Output: VGA-0, Detected Monitor Type: 0
(II) RADEON(0): Found color CRT connected to primary DAC
finished output detect: 0
(II) RADEON(0): I2C device "DVI-0:ddc2" registered at address 0xA0.
(II) RADEON(0): I2C device "DVI-0:ddc2" removed.
(II) RADEON(0): Output: DVI-0, Detected Monitor Type: 0
(II) RADEON(0): Detected non-DDC Monitor Type: 0
finished output detect: 1
finished output detect: 2
finished all detect
before xf86InitialConfiguration
in RADEONProbeOutputModes
(II) RADEON(0): Adding Screen mode: 1280x1024
(II) RADEON(0): Total number of valid Screen mode(s) added: 1
(II) RADEON(0): Output VGA-0 connected
(II) RADEON(0): Output DVI-0 disconnected
(II) RADEON(0): Output S-video disconnected
(II) RADEON(0): Output VGA-0 using initial mode 1152x768
after xf86InitialConfiguration
(==) RADEON(0): DPI set to (75, 75)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/local/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
	ABI class: X.Org ANSI C Emulation, version 0.3
(==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(==) RADEON(0): Using XAA acceleration architecture
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/local/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
	compiled for 1.4.0, module version = 1.2.0
(==) RADEON(0): Assuming overlay scaler buffer width is 1536
(II) RADEON(0): No MM_TABLE found - assuming CARD is not TV-in capable.
(!!) RADEON(0): For information on using the multimedia capabilities
	of this adapter, please see http://gatos.sf.net.
(!!) RADEON(0): MergedFB support has been removed and replaced with xrandr 1.2 support
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
	[0] 0	0	0xcfff0000 - 0xcfffffff (0x10000) MX[B]
	[1] 0	0	0xc0000000 - 0xc7ffffff (0x8000000) MX[B]
	[2] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[3] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[4] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[5] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[6] -1	0	0xcffec000 - 0xcffecfff (0x1000) MX[B]E
	[7] -1	0	0xcffef000 - 0xcffeffff (0x1000) MX[B]E
	[8] -1	0	0xcffee000 - 0xcffeefff (0x1000) MX[B]E
	[9] -1	0	0xcffed000 - 0xcffedfff (0x1000) MX[B]E
	[10] -1	0	0xd0000000 - 0xcfffffff (0x0) MX[B]EO
	[11] -1	0	0xcfee0000 - 0xcfefffff (0x20000) MX[B](B)
	[12] -1	0	0xa0000000 - 0xa7ffffff (0x8000000) MX[B](B)
	[13] -1	0	0xcff90000 - 0xcff9ffff (0x10000) MX[B](B)
	[14] -1	0	0xb8000000 - 0xbfffffff (0x8000000) MX[B](B)
	[15] -1	0	0xcffc0000 - 0xcffdffff (0x20000) MX[B](B)
	[16] -1	0	0xcfff0000 - 0xcfffffff (0x10000) MX[B](B)
	[17] -1	0	0xc0000000 - 0xc7ffffff (0x8000000) MX[B](B)
	[18] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B](OprU)
	[19] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B](OprU)
	[20] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B](OprU)
	[21] 0	0	0x0000d800 - 0x0000d8ff (0x100) IX[B]
	[22] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[23] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[24] -1	0	0x0000d000 - 0x0000d0ff (0x100) IX[B]E
	[25] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[B]E
	[26] -1	0	0x0000dc00 - 0x0000dcff (0x100) IX[B]E
	[27] -1	0	0x0000ff00 - 0x0000ffff (0x100) IX[B]E
	[28] -1	0	0x0000ac00 - 0x0000ac7f (0x80) IX[B](B)
	[29] -1	0	0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
	[30] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
	[31] 0	0	0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) RADEON(0): RADEONScreenInit c0000000 0 0
(==) RADEON(0): Write-combining range (0xc0000000,0x8000000)
(==) RADEON(0): Write-combining range (0xa0000,0x10000) was already clear
Entering TV Save
Save TV timing tables
saveTimingTables: reading timing tables
TV Save done
disable montype: 1
(II) RADEON(0): RADEONInitMemoryMap() :
(II) RADEON(0):   mem_size         : 0x08000000
(II) RADEON(0):   MC_FB_LOCATION   : 0xc7ffc000
(II) RADEON(0):   MC_AGP_LOCATION  : 0xffffffc0
(II) RADEON(0): Depth moves disabled by default
(II) RADEON(0): Memory manager initialized to (0,0) (1600,8191)
(II) RADEON(0): Reserved area from (0,1200) to (1600,1202)
(II) RADEON(0): Largest offscreen area available: 1600 x 6989
disable montype: 1
init memmap
init common
init crtc1
init pll1
freq: 64995000
best_freq: 64991803
best_feedback_div: 881
best_ref_div: 61
best_post_div: 6
restore memmap
(II) RADEON(0): RADEONRestoreMemMapRegisters() :
(II) RADEON(0):   MC_FB_LOCATION   : 0xc7ffc000 0x1fff0000
restore common
restore crtc1
restore pll1
finished PLL1
restore dac
enable montype: 1[COLOR="Silver"][B]
(WW) RADEON(0): No crtc mode list for crtc 1,continuing with desired mode
disable montype: 1
(==) RADEON(0): Backing store disabled
(WW) RADEON(0): Direct rendering disabled[/B][/COLOR]
(II) RADEON(0): Render acceleration enabled
(**) RADEON(0): Option "XaaNoOffscreenPixmaps" "True"
(II) RADEON(0): Using XFree86 Acceleration Architecture (XAA)
	Screen to screen bit blits
	Solid filled rectangles
	8x8 mono pattern filled rectangles
	Indirect CPU to Screen color expansion
	Solid Lines
	Scanline Image Writes
	Setting up tile and stipple cache:
		32 128x128 slots
		32 256x256 slots
		16 512x512 slots
(II) RADEON(0): Acceleration enabled
(==) RADEON(0): Silken mouse enabled
(II) RADEON(0): Using hardware cursor 0 (scanline 1202)
(II) RADEON(0): Using hardware cursor 1 (scanline 1204)
(II) RADEON(0): Largest offscreen area available: 1600 x 6983
(II) RADEON(0): No video input capabilities detected and no information is provided - disabling multimedia i2c
(II) Loading sub module "theatre_detect"
(II) LoadModule: "theatre_detect"
(II) Loading /usr/local/lib/xorg/modules/multimedia//theatre_detect_drv.so
(II) Module theatre_detect: vendor="X.Org Foundation"
(II) RADEON(0): no multimedia table present, disabling Rage Theatre.
(II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(WW) RADEON(0): Option "DisableGLXRootClipping" is not used
(WW) RADEON(0): Option "AddARGBGLXVisuals" is not used
(WW) RADEON(0): Option "AllowGLXWithComposite" is not used
(--) RandR disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) AIGLX: Screen 0 is not DRI capable
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/local/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(II) RADEON(0): Setting screen physical size to 304 x 203
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/sysmouse"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: always reports core events
(**) Option "Device" "/dev/sysmouse"
(==) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5 6 7"
(**) Mouse0: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Mouse0: Buttons: 11
(**) Mouse0: Sensitivity: 1
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard0: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) Mouse0: SetupAuto: hw.iftype is 4, hw.model is 0
(II) Mouse0: SetupAuto: protocol is SysMouse
enable montype: 1
disable montype: 1
(II) RADEON(0):   MC_FB_LOCATION   : 0x1fff0000 0xc7ffc000
(II) RADEON(0):   MC_AGP_LOCATION  : 0x27ff2000
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore Timing Tables
Restore TV standard
Leaving Restore TV
FreeFontPath: FPE "/usr/local/lib/X11/fonts/misc/" refcount is 2, should be 1; fixing.
ich habe unter /dev/dri keine card0-Datei. Nur eine card1 (mein Onboardgrafikchip von SiS) :(
