Probleme mit Installation Nvidia-Treiber
AntonA
Ich habe Probleme bei der Installation des NVidia Treiber 7667 für meine GF 6800 Karte.
Die Installation an sich lief OK, die Einträge in die xorg.conf sollten auch stimmen
Ausschnitt:
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/TTF/"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "Module"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "record"
Load "xtrap"
Load "freetype"
Load "type1"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
EndSection
Identifier "Keyboard1"
Driver "keyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "de"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
### Uncomment if you don't want to default to DDC:
# HorizSync 31.5 - 92.0
# VertRefresh 50.0 - 90.0
EndSection
Section "Device"
### [arg]: arg optional
#Option "DigitalVibrance" # <i>
#Option "NoFlip" # [<bool>]
#Option "Dac8Bit" # [<bool>]
#Option "NoLogo" # [<bool>]
#Option "UBB" # [<bool>]
#Option "Stereo" # <i>
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "VideoKey" # <i>
#Option "NvAGP" # <i>
#Option "IgnoreEDID" # [<bool>]
#Option "NoDDC" # [<bool>]
#Option "ConnectedMonitor" # <str>
#Option "ConnectedMonitors" # <str>
#Option "TVStandard" # <str>
#Option "TVOutFormat" # <str>
#Option "RenderAccel" # [<bool>]
#Option "CursorShadow" # [<bool>]
#Option "CursorShadowAlpha" # <i>
#Option "CursorShadowXOffset" # <i>
#Option "CursorShadowYOffset" # <i>
#Option "UseEdidFreqs" # [<bool>]
#Option "FlatPanelProperties" # <str>
#Option "TwinView" # [<bool>]
#Option "TwinViewOrientation" # <str>
#Option "SecondMonitorHorizSync" # <str>
#Option "SecondMonitorVertRefresh" # <str>
#Option "MetaModes" # <str>
#Option "UseInt10Module" # [<bool>]
#Option "NoTwinViewXineramaInfo" # [<bool>]
#Option "NoRenderExtension" # [<bool>]
#Option "Overlay" # [<bool>]
#Option "CIOverlay" # [<bool>]
#Option "ForceEmulatedOverlay" # [<bool>]
#Option "TransparentIndex" # <i>
#Option "OverlayDefaultVisual" # [<bool>]
#Option "NvEmulate" # <i>
#Option "NoBandWidthTest" # [<bool>]
#Option "CustomEDID-CRT-0" # <str>
#Option "CustomEDID-CRT-1" # <str>
#Option "CustomEDID-DFP-0" # <str>
#Option "CustomEDID-DFP-1" # <str>
#Option "CustomEDID-TV-0" # <str>
#Option "CustomEDID-TV-1" # <str>
#Option "TVOverScan" # <f>
#Option "IgnoreDisplayDevices" # <str>
#Option "MultisampleCompatibility" # [<bool>]
#Option "RegistryDwords" # <str>
#Option "RegistryBinary" # <str>
#Option "NoPowerConnectorCheck" # [<bool>]
#Option "AllowDFPStereo" # [<bool>]
#Option "XvMCUsesTextures" # [<bool>]
#Option "HorizSync" # <str>
#Option "VertRefresh" # <str>
#Option "AllowGLXWithComposite" # [<bool>]
#Option "RandRRotation" # [<bool>]
#Option "ExactModeTimingsDVI" # [<bool>]
#Option "Coolbits" # <i>
#Option "AllowDDCCI" # [<bool>]
#Option "ConstantFrameRateHint" # [<bool>]
#Option "LoadKernelModule" # [<bool>]
#Option "ClearCube" # [<bool>]
Identifier "Card0"
Driver "nvidia"
VendorName "nVidia Corporation"
BoardName "Unknown Board"
ChipSet "GeForce 6800"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Group 0
EndSection​
Trotzdem kommt nach bei "startx" die eine Fehlermldung.
Hier der Ausschnitt aus der Xorg.0.log:
(II) NVIDIA X Driver 1.0-7667 Fri Jun 17 07:24:29 PDT 2005
(II) NVIDIA Unified Driver for all NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(WW) NVIDIA: Chipset "GeForce 6800" in Device section "Card0" isn't valid for this driver
(EE) No devices detected.
Fatal server error:
no screens found​
Der Treiber sollte eigentlich die Karte unterstützen, zumindest nach der Seite von Nvidia.
Hat jemand eine Idee?
Ich schätze, dass es an der Zeile
liegt. Kommentier die mal aus und versuche es dann. Unter Linux macht genau die auch immer wieder Probleme - und den Chipsatz sollte er auch von alleine erkennen.
xorg.conf
ich habe auch die GF 6800 versuche mal das;
Section "Device"
Identifier "NVIDIA Corporation NV40 [GeForce 6800]"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "NoLogo"
#ChipSet "GeForce 6800"
#VendorName "nVidia Corporation"
#BoardName "Unknown Board"
Section "Screen"
Device "NVIDIA Corporation NV40 [GeForce 6800]"
Monitor "Monitor0"
DefaultDepth 24
Viewport 0 0
Depth 24
Modes "1280x1024"
EndSubSection
EndSection
(wenn 1280x1024 ok ist)
Zum vergleich meine xorg.conf;
Identifier "Layout0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "freetype"
#Load "xtt"
Load "extmod"
Load "glx"
Load "dri"
Load "dbe"
Load "record"
Load "xtrap"
Load "type1"
#Load "speedo"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "Auto"
Option "Emulate3Buttons" "true"
Option "CorePointer"
Option "ZAxisMapping" "4 5"
EndSection
Driver "keyboard"
EndSection
Section "Monitor"
# HorizSync 31.5 - 79.0
# VertRefresh 50.0 - 70.0
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:1:0:0"
#Option "NvAGP" "0"
Option "TwinView" "true"
Option "TwinViewOrientation" "RightOf"
Option "MetaModes" "1280x1024, 1280x1024; 1024x768, 1024x768;"
Option "SecondMonitorHorizSync" "30-80"
Option "SecondMonitorVertRefresh" "55-75"
Option "ConnectedMonitor" "tft,tft"
Option "NoLogo"
#Card "nv GeForce 6800"
EndSection
Section "Screen"
Monitor "Monitor0"
DefaultDepth 24
Viewport 0 0
Depth 24
Modes "1280x1024"
EndSubSection
EndSection
Hallo!
Ich hab FreeBSD erst zeit kurzer Zeit und kenn mich nich toll damit aus.
Ich hab eien Geforce 6800gt und und kann denn x-server nicht starten. Wie kann ich den nvidia treiber installieren, bitte helft mir!
schon mal danke im voraus
Das wars!!
Jetzt funktioniert es. Da soll man mal drauf kommen....
Vielen Dank an alle!
/A
(endlich wieder mit farbenfrohem Bildschirm)
Mosi schrieb:
Hallo!
Lies bitte das Handbuch, es gibt dort einen ganzen Abschnitt zum Thema Software installieren und aktuell halten.
Oder benutze die Forensuche, die Frage ist hier täglich einmal an der Reihe ..
hi
ich benutz immer den aktuellen treiber von der nvidia seite und bau ihn dann mit "make setup".kann zwar den auch aus den ports installieren doch dann macht X die selben fehlermeldungen.versuch das mal.
mfg
ZeroSix
Die Chipset-Option ist inzwischen praktisch überflüssig. Die wurde glaub ich früher mal verwendet, als die Treiber die Chipsets noch nicht selber erkennen konnten. Heutzutage kann das aber praktisch jeder Treiber. Die Wahrscheinlichkeit, daß es einen Treiber gibt der das nicht kann ist imho 0. Eher gibt es für das entsprechende Gerät garkeinen Treiber.
Soll heißen: die Option kannst getrost weglassen.
