hallo,
habe hier einen coolen effect, habe FreeBSD 5-4PL8 und samba 3.0.20b aus den
ports installiert. habe eine freigabe erzeugt, auf der alle zugriffe als ein bestimmter
user ausgeführt werden. losche ich dateien und verzeichnisse von dieser freigabe,
so werden dateien und verzeichnisse geloescht, aber nach einem refresh sind nur
die verzeichnisse wieder da. total spooky, hatte ich noch nie
[global]
workgroup = WORKGROUP
netbios name = ENGINEERING
server string = Engineering IntraNet Server
security = SHARE
encrypt passwords = Yes
log file = /var/log/samba/%m.log
log level = 3
max log size = 1000
name resolve order = host bcast lmhosts
local master = No
socket options = TCP_NODELAY
load printers = Yes
unix charset = ISO8859-1
display charset = ISO8859-1
dos charset = cp852
recycle:repository = .recycle/%m
recycle:keeptree = yes
recycle:versions = yes
recycle:maxsize = 0
recycle:exclude = *.tmp|*.temp|*.o|*.obj|~$*
recycle:excludedir = /tmp|/temp|/cache
recycle:noversions = *.doc|*.xls|*.ppt
vfs objects = recycle
[collage]
comment = Grass Valley Profile Backup
path = /netdrive/collage
username = collage
valid users = collage
force user = collage
read only = No
create mask = 0655
directory mask = 0755
guest only = Yes
guest ok = Yes
hosts allow = 172.25.202.
strict locking = Yes
[global]
security = SHARE
log level = 3
max log size = 1000
local master = No
load printers = Yes
dos charset = cp852
recycle:maxsize = 0
[collage]
username = collage
read only = No
create mask = 0655
guest only = Yes
guest ok = Yes
