FreeBSD 5.3-RELEASE #0: Fri Nov 5 04:19:18 UTC 2004
root@harlow.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC
CPU: Pentium II/Pentium II Xeon/Celeron (265.26-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0x652 Stepping = 2
Features=0x183f9ff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR>
real memory = 134021120 (127 MB)
avail memory = 121483264 (115 MB)
npx0: [FAST]
npx0: INT 16 interface
acpi0: <IBM TP600> on motherboard
acpi0: Power Button (fixed)
acpi_ec0: <Embedded Controller: GPE 0x9, GLK> port 0x66,0x62 on acpi0
Timecounter "ACPI-safe" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0xef08-0xef0b on acpi0
cpu0: <ACPI CPU (2 Cx states)> port 0x530-0x537 on acpi0
acpi_tz0: <Thermal Zone> port 0x530-0x537 on acpi0
acpi_tz1: <Thermal Zone> port 0x530-0x537 on acpi0
acpi_tz2: <Thermal Zone> port 0x530-0x537 on acpi0
acpi_lid0: <Control Method Lid Switch> on acpi0
acpi_button0: <Sleep Button> on acpi0
pci0: <ACPI PCI bus> on pcib0
cbb0: <TI1250 PCI-CardBus Bridge> mem 0x20301000-0x20301fff at device 2.0 on pci0
cbb1: <TI1250 PCI-CardBus Bridge> mem 0x20300000-0x20300fff at device 2.1 on pci0
cardbus1: <CardBus bus> on cbb1
pccard1: <16-bit PCCard bus> on cbb1
pci0: <display, VGA> at device 3.0 (no driver attached)
isab0: <PCI-ISA bridge> at device 7.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel PIIX4 UDMA33 controller> port 0xfcf0-0xfcff,0x376,0x170-0x177,0x3f6,0x1f0-0x1f7 at device 7.1 on pci0
ata0: channel #0 on atapci0
ata1: channel #1 on atapci0
uhci0: <Intel 82371AB/EB (PIIX4) USB controller> port 0x8400-0x841f irq 10 at device 7.2 on pci0
uhci0: [GIANT-LOCKED]
usb0: <Intel 82371AB/EB (PIIX4) USB controller> on uhci0
usb0: USB revision 1.0
pci0: <bridge, PCI-unknown> at device 7.3 (no driver attached)
fdc0: <floppy drive controller (FDE)> port 0x3f7,0x3f0-0x3f5 irq 6 drq 2 on acpi0
fdc0: [FAST]
sio0: configured irq 4 not in bitmap of probed irqs 0
sio0: port may not be enabled
ppc0: <Standard parallel printer port> port 0x3bc-0x3bf irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
sio0: <Generic IRDA-compatible device> port 0x3f8-0x3ff irq 4 drq 3 flags 0x10 on acpi0
sio0: type 16550A
pcm0: <CS423x> port 0x220-0x233,0x388-0x38b,0x530-0x537 irq 5 drq 0,1 on acpi0
pcm0: [GIANT-LOCKED]
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: [GIANT-LOCKED]
psm0: model Generic PS/2 mouse, device ID 0
acpi_cmbat0: <Control Method Battery> on acpi0
acpi_acad0: <AC Adapter> on acpi0
sio1: configured irq 4 not in bitmap of probed irqs 0
sio1: port may not be enabled
orm0: <ISA Option ROM> at iomem 0xc0000-0xc9fff on isa0
pmtimer0 on isa0
Timecounter "TSC" frequency 265264867 Hz quality 800
Interrupt storm detected on "irq10: cbb1 uhci0"; throttling interrupt source
acpi_cpu: throttling enabled, 8 steps (100% to 12.5%), currently 100.0%
dc0: <Xircom X3201 10/100BaseTX> port 0x1000-0x107f mem 0x20302000-0x203027ff,0x20302800-0x20302fff irq 10 at device 0.0 on cardbus1
miibus0: <MII bus> on dc0
tdkphy0: <TDK 78Q2120 media interface> on miibus0
tdkphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
dc0: Ethernet address: 00:10:a4:76:e1:83
dc0: if_start running deferred for Giant
dc0: [GIANT-LOCKED]
ad0: 9590MB <TOSHIBA MK1017GAP/A4.01 A> [19485/16/63] at ata0-master UDMA33
acd0: CDROM <TOSHIBA CD-ROM XM-1702BC/1562> at ata1-master PIO4
Mounting root from ufs:/dev/ad0s1a
Interrupt storm detected on "irq11: cbb0"; throttling interrupt source
