FreeBSD 5.3-RELEASE #0: Fri Nov 5 04:19:18 UTC 2004
root@harlow.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC
CPU: Intel Pentium III (312.40-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0x686 Stepping = 6
Features=0x387f9ff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,PN,MMX,FXSR,SSE>
real memory = 201261056 (191 MB)
avail memory = 187265024 (178 MB)
npx0: [FAST]
npx0: INT 16 interface
acpi0: <PTLTD RSDT> on motherboard
ACPI-1303: *** Error: Method execution failed [\\_SB_.PCI0._INI] (Node 0xc13ce260), AE_AML_NO_RETURN_VALUE
acpi0: Power Button (fixed)
acpi_ec0: <Embedded Controller: GPE 0x9, GLK> port 0x66,0x62 on acpi0
Timecounter "ACPI-safe" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
cpu0: <ACPI CPU (3 Cx states)> on acpi0
acpi_lid0: <Control Method Lid Switch> on acpi0
acpi_button0: <Sleep Button> on acpi0
pci0: <ACPI PCI bus> on pcib0
agp0: <Intel 82443BX (440 BX) host to PCI bridge> mem 0xf8000000-0xfbffffff at device 0.0 on pci0
pci1: <ACPI PCI bus> on pcib1
isab0: <PCI-ISA bridge> at device 7.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel PIIX4 UDMA33 controller> port 0x1800-0x180f,0x376,0x170-0x177,0x3f6,0x1f0-0x1f7 at device 7.1 on pci0
ata0: channel #0 on atapci0
ata1: channel #1 on atapci0
uhci0: <Intel 82371AB/EB (PIIX4) USB controller> port 0x1820-0x183f irq 11 at device 7.2 on pci0
uhci0: [GIANT-LOCKED]
usb0: <Intel 82371AB/EB (PIIX4) USB controller> on uhci0
usb0: USB revision 1.0
pci0: <bridge, PCI-unknown> at device 7.3 (no driver attached)
cbb0: <RF5C476 PCI-CardBus Bridge> mem 0x50000000-0x50000fff irq 11 at device 8.0 on pci0
cbb1: <RF5C476 PCI-CardBus Bridge> mem 0x50100000-0x50100fff irq 11 at device 8.1 on pci0
cardbus1: <CardBus bus> on cbb1
pccard1: <16-bit PCCard bus> on cbb1
fxp0: <Intel 82559ER Pro/100 Ethernet> port 0x1840-0x187f mem 0xf4020000-0xf403ffff,0xf4010000-0xf4010fff irq 11 at device 10.0 on pci0
miibus0: <MII bus> on fxp0
inphy0: <i82555 10/100 media interface> on miibus0
inphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
fxp0: Ethernet address: 00:10:a4:15:e2:9f
pci0: <simple comms, UART> at device 10.1 (no driver attached)
pcm0: <Crystal Semiconductor CS4281> mem 0xf4000000-0xf400ffff,0xf4012000-0xf4012fff irq 11 at device 11.0 on pci0
pcm0: [GIANT-LOCKED]
pcm0: <Cirrus Logic CS4297A AC97 Codec>
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: <PS/2 Mouse> flags 0x3000 irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
psm0: model Generic PS/2 mouse, device ID 0
fdc0: <floppy drive controller (FDE)> port 0x3f7,0x3f0-0x3f5 irq 6 drq 2 on acpi0
fdc0: [FAST]
sio0: configured irq 4 not in bitmap of probed irqs 0
sio0: port may not be enabled
ppc0: <Standard parallel printer port> port 0x3bc-0x3bf irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
acpi_cmbat0: <Control Method Battery> on acpi0
acpi_acad0: <AC Adapter> on acpi0
orm0: <ISA Option ROMs> at iomem 0xdc000-0xdcfff,0xd8000-0xdbfff,0xcd000-0xce7ff on isa0
pmtimer0 on isa0
sio0: type 8250 or not responding
sio1: port may not be enabled
Timecounter "TSC" frequency 312395627 Hz quality 800
acpi_cpu: throttling enabled, 8 steps (100% to 12.5%), currently 100.0%
pff0: <Intersil PRISM Duette/Prism GT Wireless LAN adapter> mem 0x20000000-0x20001fff irq 11 at device 0.0 on cardbus0
pff0: Ethernet address: 00:50:fc:b7:2f:69
pff0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
pff0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
ad0: 38154MB <TOSHIBA MK4019GAX/FA002A> [77520/16/63] at ata0-master UDMA33
pccard1: Allocation failed for cfe 0
ata2: <Transcend 128M > at port 0x100-0x10f irq 11 function 0 config 1 on pccard1
ad4: 122MB <Transcend 128M/1.1> [978/8/32] at ata2-master PIO4
Mounting root from ufs:/dev/ad0s1a
WARNING: /extern was not properly dismounted
pflog0: promiscuous mode enabled
uhub1: Texas Instruments General Purpose USB Hub, class 9/0, rev 1.10/1.01, addr 2
ums0: Logitech USB-PS/2 Optical Mouse, rev 2.00/21.00, addr 3, iclass 3/1
ums0: 7 buttons and Z dir.
