Einen wunderschönen guten abend ...
zu allererst mal das system:
AmD Athlon xp 2800+
1gm ram
nforce2 chipsatz
blabla, dmsg:
Copyright (c) 1992-2005 The FreeBSD Project.
FreeBSD 5.4-STABLE #0: Thu Nov 10 18:06:30 CET 2005
root@stellamaris.ath.cx:/usr/obj/usr/src/sys/STELLA
CPU: AMD Athlon(tm) XP 2800+ (2088.08-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x6a0 Stepping = 0
Features=0x383fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE>
AMD Features=0xc0400000<AMIE,DSP,3DNow!>
real memory = 1073676288 (1023 MB)
avail memory = 1036922880 (988 MB)
mptable_probe: MP Config Table has bad signature: eft
ACPI APIC Table: <Nvidia AWRDACPI>
ioapic0 <Version 1.1> irqs 0-23 on motherboard
npx0: INT 16 interface
acpi0: <Nvidia AWRDACPI> on motherboard
acpi0: Power Button (fixed)
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
cpu0: <ACPI CPU> on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: <memory, RAM> at device 0.1 (no driver attached)
pci0: <memory, RAM> at device 0.2 (no driver attached)
pci0: <memory, RAM> at device 0.3 (no driver attached)
pci0: <memory, RAM> at device 0.4 (no driver attached)
pci0: <memory, RAM> at device 0.5 (no driver attached)
isab0: <PCI-ISA bridge> at device 1.0 on pci0
isa0: <ISA bus> on isab0
pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
ohci0: <OHCI (generic) USB controller> mem 0xe5000000-0xe5000fff irq 22 at device 2.0 on pci0
usb0: <OHCI (generic) USB controller> on ohci0
usb0: USB revision 1.0
uhub0: nVidia OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub0: 3 ports with 3 removable, self powered
ohci1: <OHCI (generic) USB controller> mem 0xe5001000-0xe5001fff irq 21 at device 2.1 on pci0
usb1: OHCI version 1.0, legacy support
usb1: <OHCI (generic) USB controller> on ohci1
usb1: USB revision 1.0
uhub1: nVidia OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub1: 3 ports with 3 removable, self powered
pci0: <serial bus, USB> at device 2.2 (no driver attached)
pcib1: <ACPI PCI-PCI bridge> at device 8.0 on pci0
pci1: <ACPI PCI bus> on pcib1
bktr0: <BrookTree 878> mem 0xe0000000-0xe0000fff irq 19 at device 7.0 on pci1
bktr0: Leadtek Winfast TV 2000, Philips FR1236 NTSC FM tuner.
pci1: <multimedia> at device 7.1 (no driver attached)
pcm0: <CMedia CMI8738> port 0xc000-0xc0ff irq 17 at device 9.0 on pci1
pci1: <network> at device 10.0 (no driver attached)
rl0: <RealTek 8139 10/100BaseTX> port 0xc400-0xc4ff mem 0xe4022000-0xe40220ff irq 19 at device 11.0 on pci1
miibus0: <MII bus> on rl0
rlphy0: <RealTek internal media interface> on miibus0
rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
rl0: Ethernet address: 00:04:61:4b:22:60
atapci0: <SiI 3112 SATA150 controller> port 0xd800-0xd80f,0xd400-0xd403,0xd000-0xd007,0xcc00-0xcc03,0xc800-0xc807 mem 0xe4023000-0xe40231ff irq 16 at device 12.0 on pci1
ata2: channel #0 on atapci0
ata3: channel #1 on atapci0
pci1: <serial bus, FireWire> at device 13.0 (no driver attached)
atapci1: <nVidia nForce2 UDMA133 controller> port 0xf000-0xf00f,0x376,0x170-0x177,0x3f6,0x1f0-0x1f7 at device 9.0 on pci0
ata0: channel #0 on atapci1
ata1: channel #1 on atapci1
pcib2: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci2: <ACPI PCI bus> on pcib2
nvidia0: <GeForce4 Ti 4200 with AGP8X> mem 0xd8000000-0xdfffffff,0xe1000000-0xe1ffffff irq 19 at device 0.0 on pci2
fdc0: <floppy drive controller> port 0x3f7,0x3f0-0x3f5 irq 6 drq 2 on acpi0
sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
sio0: type 16550A
sio1: <16550A-compatible COM port> port 0x2f8-0x2ff irq 3 on acpi0
sio1: type 16550A
ppc0: <Standard parallel printer port> port 0x778-0x77b,0x378-0x37f irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
ppbus0: IEEE1284 device found /NIBBLE
Probing for PnP devices on ppbus0:
ppbus0: <Hewlett-Packard LaserJet 4L> HP ENHANCED PCL5,PJL
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
kbd0 at atkbd0
psm0: model IntelliMouse, device ID 3
pmtimer0 on isa0
orm0: <ISA Option ROM> at iomem 0xd0000-0xd47ff on isa0
uscanner0: Canon CanoScan, rev 1.10/1.00, addr 2
ugen0: OmniVision OV511+ Camera, rev 1.00/1.00, addr 3
Timecounter "TSC" frequency 2088080455 Hz quality 800
acd0: DVDROM <TOSHIBA DVD-ROM SD-M1712/1004> at ata0-master PIO4
acd1: CDRW <SONY CD-RW CRX220E1/6YS1> at ata1-master PIO4
ad4: 117246MB <Maxtor 6Y120M0/YAR51BW0> [238216/16/63] at ata2-master SATA150
cd1 at ata1 bus 0 target 0 lun 0
cd1: <SONY CD-RW CRX220E1 6YS1> Removable CD-ROM SCSI-0 device
cd1: 16.000MB/s transfers
cd1: Attempt to query device size failed: NOT READY, Medium not present
cd0 at ata0 bus 0 target 0 lun 0
cd0: <TOSHIBA DVD-ROM SD-M1712 1004> Removable CD-ROM SCSI-0 device
cd0: 16.000MB/s transfers
Mounting root from ufs:/dev/ad4s1a
ndis0: <NETGEAR WG311v2 802.11g Wireless PCI Adapter> mem 0xe4000000-0xe401ffff,0xe4020000-0xe4021fff irq 18 at device 10.0 on pci1
ndis0: NDIS API version: 5.1
ndis0: Ethernet address: 00:0f:b5:43:72:9d
ndis0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
ndis0: 11g rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
so das wäre nur für die die'S wissen wollen....
ich sitze gerade rum und bastelte in meine gurke eine TV karte ein (eben jene oben erwähnte), diese besitzt einen Brook tree (bt878) also ist das vidoe capture schon mal möglich. des weiteren sagt mir der dmesg
also alles ok, bis datum. den tuner habe ich dan versucht via sysctl auf pal umzustellen,
sysctl hw.bt848.tuner=5 (der Philips ohne Radio .... was es eigendlich sein müßte)
oder auch
sysctl hw.bt848.tuner=10 (der philips tuner pal mit radio ... der sollte laut der einen oder anderen resource im weltnetz funktionieren ..) so anchde das dann alles getan wurde, versuch bewegte bilder zu sehen! ---> fxtv basteln (mittels ports)
aber beim start verabschiedert sich fxtv auch gleich wieder mit einer speicher schutzverletzug (oder segmentation fault!).
jegliche optimierungen abgeschaltet, und das proggie (inkliusive seiner abhängigkeiten) ohne optimierungen neu gebaut ..... selbes ergebnis
pid 6852 (fxtv), uid 1001: exited on signal 11 (core dumped)
für alle die's genauer interessiert
also, versuch mittels xawtv -device /dev/bktr0
tv norm auf pal setzen, frequenztabelle ist die in deutschland gültige europe-west ... keine bewegten bilder (dafür aber armeisenpornos .. hey immerhin was ...)
so zum testen aml 'ne digicam an'S composite angeschlossen .. wunderbar, alles funzt ....
zwischenstand: karte funktioniert, prinzipiell!
nach einigen versuchen sender zu finden .. habe ich mal ein sehr schlechtes bild von aljasihra (ich glaube den schreibt man so) gesehen ....
aber sonst sehe ich nix auch nicht mit mplayer ---- nur armeisenpornos
letzter stand .... karte wird an un für sich unterstützt .... aber ich bekomme nix zu sehen ....
hat irgender von euch andere erfahrungen mit dieser karte gemacht, her damit ...
sollte die bei irgendwem auch noch bewegt bilder ausspucken .. kann alles brauchen
so denn merci vielmals ..
AmD Athlon xp 2800+
1gm ram
nforce2 chipsatz
blabla, dmsg:
sio0: type 16550A
sio1: type 16550A
kbd0 at atkbd0
pmtimer0 on isa0
oder auch
