#> edit /etc/make.conf
# deskutils/kdepim3
.if${.CURDIR:M*/usr/ports/deskutils/kdepim3}
DO_NOT_COMPILE+=kandy kalarm karm kontact korn kpilot multisynk kitchensync wizards
.endif
# graphics/kdegraphics3
.if${.CURDIR:M*/usr/ports/graphics/kdegraphics3}
WITH_IMLIB=yes
WITH_GPHOTO2=yes
WITH_SANE=yes
DO_NOT_COMPILE+=kiconedit kolourpaint kpovmodeler kview kdvi
.endif
# misc/kdeutils3
.if${.CURDIR:M*/usr/ports/misc/kdeutils3}
DO_NOT_COMPILE+=charselectapplet kcharselect kdelirc kdf kedit khexedit kjots kregexpeditor ksim ktimer superkaramba
.endif
# multimedia/kdemultimedia3
.if${.CURDIR:M*/usr/ports/multimedia/kdemultimedia3}
WITHOUT_AKODE=yes
WITH_XINE=yes
WITH_MPEGLIB=yes
DO_NOT_COMPILE+=noatun kaboodle akode_artsplugin kmid krec
.endif
# net/kdenetwork3
.if${.CURDIR:M*/usr/ports/net/kdenetwork3}
WITH_KOPETE=yes
DO_NOT_COMPILE+=kdict knewsticker kpf kppp krfb ksirc ktalkd
.endif
# x11/kdebase3
.if${.CURDIR:M*/usr/ports/x11/kdebase3}
WITH_HTDIG=yes
WITH_HAL=yes
DO_NOT_COMPILE+=kappfinder
.endif
5.7.3.1 The KDE Display Manager
An administrator of a multi-user system may wish to have a graphical login screen to welcome users. XDM can be used, as described earlier. However, KDE includes an alternative, kdm, which is designed to look more attractive and include more login-time options. In particular, users can easily choose (via a menu) which desktop environment (KDE, GNOME, or something else) to run after logging on.
To enable kdm, the ttyv8 entry in /etc/ttys has to be adapted. The line should look as follows:
ttyv8 "/usr/local/bin/kdm -nodaemon" xterm on secure
