%su
Password:
pcbsd# scanimage -L
device `plustek:/dev/uscanner0' is a Hewlett-Packard Scanjet 2200c flatbed scanner
%su
Password:
pcbsd# sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x03f0, product=0x0605) at /dev/uscanner0
# Your USB scanner was detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
pcbsd#
