Herakles
Profifragensteller
Moinserich alle t'sammen!
Musste mir Dank einer behinderten Windows-Installation, die mir alles zerschossen hat, tatsächlich mein FBSD neu installieren. Nun bekomme ich jedoch bei der Firefox - Installation aus den Ports folgende Meldung:
quote
checking for XML::Parser... configure: error: XML::Parser perl module is required for intltool
===> Script "configure" failed unexpectedly.
Please direct the output of the failure of the make command to a file, and
then feed that file to the gnomelogalyzer, available from
http://www.freebsd.org/gnome/gnomelogalyzer.sh, which will diagnose the problem
and suggest a solution. If - and only if - the gnomelogalyzer cannot solve
the problem, report the problem to the FreeBSD GNOME team at gnome@FreeBSD.org,
and attach "/usr/ports/devel/gnomevfs2/work/gnome-vfs-2.10.0/config.log" and
the output of the failure of the make command. Also, it might be a good idea
to provide an overview of all packages installed on your system (e.g. an `ls
/var/db/pkg`).
*** Error code 1
Stop in /usr/ports/devel/gnomevfs2.
*** Error code 1
Stop in /usr/ports/www/firefox.
s077a#
/quote
p5-XML-Parser ist die neuste Version drauf. Nach langem Tüfteln bin ich bisher nur hierher gekommen. Hat jemand ne Idee?
Herakles
quote
/var/db/pkg`).
*** Error code 1
*** Error code 1
s077a#
/quote
Herakles
