r2d2
Poste mal deine xorg.conf und dein Xorg.0.log
les doch mal die Antworten hier, hab schonma geschrieben das du es mit ner anderen Auflösung probieren sollst, das andere is die xorg.conf und die Xorg.0.log................
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (root@gohan31.freebsd.org) Wed Mar 15 22:22:07 UTC 2006
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/TTF/"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "glx"
Load "record"
Load "xtrap"
Load "freetype"
Load "type1"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
#DisplaySize 470 300 # mm
### Comment all HorizSync and VertSync values to use DDC:
Identifier "Monitor0"
VendorName "ACR"
ModelName "Acer AL2216W"
HorizSync 30.0 - 82.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "UseFBDev" # [<bool>]
#Option "Rotate" # [<str>]
#Option "VideoKey" # <i>
#Option "FlatPanel" # [<bool>]
#Option "FPDither" # [<bool>]
#Option "CrtcNumber" # <i>
#Option "FPScale" # [<bool>]
#Option "FPTweak" # <i>
Identifier "Card0"
Driver "nvidia"
VendorName "nVidia Corporation"
BoardName "NV34 [GeForce FX 5500]"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
Modes "1024x768"
EndSubSection
Viewport 0 0
Depth 24
Modes "1280x1024" "1024x768"
EndSubSection
EndSection
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation CVS repository.
See http://wiki.x.org/wiki/CvsPage for CVS access instructions.
X Window System Version 6.8.99.903 (6.9.0 RC 3)
Release Date: 03 December 2005 + cvs
X Protocol Version 11, Revision 0, Release 6.8.99.903
Build Operating System: FreeBSD 6.1 i386 [ELF]
Current Operating System: FreeBSD wirmin.wir-online.org 6.1-RELEASE FreeBSD 6.1-RELEASE #0: Sun May 7 04:42:56 UTC 2006 root@opus.cse.buffalo.edu:/usr/obj/usr/src/sys/SMP i386
Build Date: 16 March 2006
Before reporting problems, check http://wiki.X.Org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Mar 13 17:45:33 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(WW) The directory "/usr/X11R6/lib/X11/fonts/CID/" does not exist.
Entry deleted from font path.
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/TTF/,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(**) ModulePath set to "/usr/X11R6/lib/modules"
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on freebsd
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.8.99.903, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.8
(--) Using syscons driver with X support (version 2.0)
(--) using VT number 9
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1039,0651 card 1043,8079 rev 02 class 06,00,00 hdr 80
(II) PCI: 00:01:0: chip 1039,0001 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 1039,0962 card 0000,0000 rev 04 class 06,01,00 hdr 80
(II) PCI: 00:02:5: chip 1039,5513 card 104d,8133 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:02:6: chip 1039,7013 card 104d,8129 rev a0 class 07,03,00 hdr 00
(II) PCI: 00:02:7: chip 1039,7012 card 104d,8127 rev a0 class 04,01,00 hdr 00
(II) PCI: 00:03:0: chip 1039,7001 card 104d,8133 rev 0f class 0c,03,10 hdr 80
(II) PCI: 00:03:1: chip 1039,7001 card 104d,8133 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:2: chip 1039,7001 card 104d,8133 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:3: chip 1039,7002 card 104d,8133 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:12:0: chip 10ec,8139 card 104d,80ea rev 10 class 02,00,00 hdr 00
(II) PCI: 00:13:0: chip 1033,00f2 card 104d,811e rev 01 class 0c,00,10 hdr 00
(II) PCI: 01:00:0: chip 10de,0326 card 10b0,0403 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xdff00000 - 0xfebfffff (0x1ed00000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:2:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV34 [GeForce FX 5500] rev 161, Mem @ 0xd7000000/24, 0xe0000000/28, BIOS @ 0xdffe0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd8000000 from 0xdfffffff to 0xd7ffffff
(II) PCI Memory resource overlap reduced 0xd6000000 from 0xd7ffffff to 0xd6ffffff
(II) PCI Memory resource overlap reduced 0xd4000000 from 0xd7ffffff to 0xd5ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xd4000000 - 0xd5ffffff (0x2000000) MX[B]E
[1] -1 0 0xd4800000 - 0xd4ffffff (0x800000) MX[B]E
[2] -1 0 0xd5000000 - 0xd5ffffff (0x1000000) MX[B]E
[3] -1 0 0xd5800000 - 0xd5ffffff (0x800000) MX[B]E
[4] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B]E
[5] -1 0 0xd6800000 - 0xd6ffffff (0x800000) MX[B]E
[6] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]EO
[7] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MX[B](B)
[8] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[9] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MX[B](B)
[10] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[11] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[12] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[13] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
[14] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
[15] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
[16] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
[17] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[18] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[19] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
(II) PCI Memory resource overlap reduced 0xd4000000 from 0xd5ffffff to 0xd47fffff
(II) PCI Memory resource overlap reduced 0xd5000000 from 0xd5ffffff to 0xd57fffff
(II) PCI Memory resource overlap reduced 0xd6000000 from 0xd6ffffff to 0xd67fffff
(II) Active PCI resource ranges after removing overlaps:
[0] -1 0 0xd4000000 - 0xd47fffff (0x800000) MX[B]E
[2] -1 0 0xd5000000 - 0xd57fffff (0x800000) MX[B]E
[4] -1 0 0xd6000000 - 0xd67fffff (0x800000) MX[B]E
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xd4000000 - 0xd47fffff (0x800000) MX[B]E
[6] -1 0 0xd4800000 - 0xd4ffffff (0x800000) MX[B]E
[7] -1 0 0xd5000000 - 0xd57fffff (0x800000) MX[B]E
[8] -1 0 0xd5800000 - 0xd5ffffff (0x800000) MX[B]E
[9] -1 0 0xd6000000 - 0xd67fffff (0x800000) MX[B]E
[10] -1 0 0xd6800000 - 0xd6ffffff (0x800000) MX[B]E
[11] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]EO
[12] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MX[B](B)
[13] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[14] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MX[B](B)
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[18] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[19] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[20] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
[21] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
[22] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
[23] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
[24] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[25] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[26] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.8178
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 6.8.99.903, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "xtrap"
(II) Loading /usr/X11R6/lib/modules/extensions/libxtrap.so
(II) Module xtrap: vendor="X.Org Foundation"
(II) Loading extension DEC-XTRAP
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.8.99.903, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.8.99.903, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: "kbd"
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 6.8.99.903, module version = 1.0.1
(II) NVIDIA dlloader X Driver 1.0-8178 Wed Dec 14 17:06:40 PST 2005
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[21] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[22] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[23] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
[24] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
[25] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
[26] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
[27] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[28] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[29] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
[30] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[31] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(--) NVIDIA(0): Linear framebuffer at 0xE0000000
(--) NVIDIA(0): MMIO registers at 0xD7000000
(II) NVIDIA(0): NVIDIA GPU detected as: GeForce FX 5500
(--) NVIDIA(0): VideoBIOS: 04.34.20.87.00
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): VideoRAM: 262144 kBytes
(II) NVIDIA(0): Connected display device(s): CRT-0
(--) NVIDIA(0): CRT-0: maximum pixel clock: 350 MHz
(II) NVIDIA(0): Frequency information for CRT-0:
(II) NVIDIA(0): HorizSync : 30.000-82.000 kHz
(II) NVIDIA(0): VertRefresh : 56.000-76.000 Hz
(II) NVIDIA(0): (HorizSync from EDID)
(II) NVIDIA(0): (VertRefresh from EDID)
(II) NVIDIA(0): Monitor0: Using hsync range of 30.00-82.00 kHz
(II) NVIDIA(0): Monitor0: Using vrefresh range of 56.00-76.00 Hz
(II) NVIDIA(0): Clock range: 12.00 to 350.00 MHz
(II) NVIDIA(0): Not using default mode "640x350" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x175" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "640x400" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x200" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "720x400" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "360x200" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "640x480" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x240" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "800x600" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "400x300" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "1024x768" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "512x384" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "1280x960" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x480" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x1024" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x512" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x600" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) NVIDIA(0): Not using default mode "896x672" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1856x1392" (hsync out of range)
(II) NVIDIA(0): Not using default mode "928x696" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1920x1440" (hsync out of range)
(II) NVIDIA(0): Not using default mode "960x720" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1152x768" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "576x384" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "2048x1536" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1024x768" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) NVIDIA(0): Not using default mode "1400x1050" (width too large for virtual size)
(**) NVIDIA(0): Validated modes for display device CRT-0:
(**) NVIDIA(0): Default mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) NVIDIA(0): Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NVIDIA(0): Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NVIDIA(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NVIDIA(0): Default mode "800x600": 87.8 MHz, 81.2 kHz, 65.0 Hz (D)
(**) NVIDIA(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NVIDIA(0): Default mode "800x600": 81.0 MHz, 75.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NVIDIA(0): Default mode "700x525": 77.9 MHz, 81.5 kHz, 74.8 Hz (D)
(**) NVIDIA(0): Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "640x512": 67.5 MHz, 80.0 kHz, 75.0 Hz (D)
(**) NVIDIA(0): Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) NVIDIA(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(--) NVIDIA(0): DPI set to (90, 88); computed from "UseEdidDpi" X config option
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 6.8.99.903, module version = 0.1.0
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
[1] 0 0 0xd7000000 - 0xd7ffffff (0x1000000) MX[B]
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xd4000000 - 0xd47fffff (0x800000) MX[B]E
[8] -1 0 0xd4800000 - 0xd4ffffff (0x800000) MX[B]E
[9] -1 0 0xd5000000 - 0xd57fffff (0x800000) MX[B]E
[10] -1 0 0xd5800000 - 0xd5ffffff (0x800000) MX[B]E
[11] -1 0 0xd6000000 - 0xd67fffff (0x800000) MX[B]E
[12] -1 0 0xd6800000 - 0xd6ffffff (0x800000) MX[B]E
[13] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]EO
[14] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MX[B](B)
[15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[16] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MX[B](B)
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[23] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[24] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[25] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
[26] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
[27] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
[28] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
[29] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[30] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[31] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
[32] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[33] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "1280x1024"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/sysmouse"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Device" "/dev/sysmouse"
(==) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5 6 7"
(**) Mouse0: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Mouse0: Buttons: 11
(**) Option "CoreKeyboard"
(**) Keyboard0: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard0: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) XINPUT: Adding extended input device "NVIDIA Event Handler" (type: Other)
(II) Mouse0: SetupAuto: hw.iftype is 4, hw.model is 0
(II) Mouse0: SetupAuto: protocol is SysMouse
Hier die Modeline
Modeline "1680x1050@60" 154.20 1680 1712 2296 2328 1050 1071 1081 1103
Viewport 0 0
Depth 24
Modes "1680x1050" "1280x1024" "1024x768"
EndSubSection
EndSection
BTW 1: Die ürbigen SubSections in Display kannst du ruhig löschen.
BTW 2: Warum nicht FreeBSD 6.2?
mousaka
(II) NVIDIA(0): Not using default mode "1680x1050"
Ich hatte mir das Buch FreeBSD 6 Unleashed gekauft. Die Version ist 6.1 und mich interessiert auch der upgrade von 6.1 nach 6.2.
Schau mal unter http://www.daemonology.net/blog/2006-11-26-freebsd-6.1-to-6.2-binary-upgrade.html
oder lade die ISO-Dateien herunter und starte von Grund auf.
mousaka
(II) NVIDIA(0): Not using mode "1680x1050" (no mode of this name)
Vermute mal, dass der Treiber nur die eingebauten Modi versteht, und 1680x1050 leider nicht dabei ist(II) NVIDIA(0): Not using mode "1680x1050" (no mode of this name)
