happy
habe cvsup gemacht auch jdk p8 ist kein problem zu bauen, aber oo 2 nix funktion.
Was mach ich falsch?
register component 'javavm.uno.so' in registry '../../unxfbsd.pro/lib/uno_services.rdb' succesful!
regcomp -register -br ../../unxfbsd.pro/misc/bridgetest/bootstrap.rdb -r ../../unxfbsd.pro/lib/uno_services.rdb -c \
file:///usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/testtools/source/bridgetest/../../unxfbsd.pro/class/testComponent.jar \
-env:URE_INTERNAL_JAVA_DIR=file:///usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/bin
using loader com.sun.star.loader.Java2
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x28CD8738
Function=inflate_fast+0xC
Library=/lib/libz.so.3
Current Java thread:
at java.util.zip.Inflater.inflateBytes(Native Method)
at java.util.zip.Inflater.inflate(Inflater.java:219)
- locked <0x2cfde658> (a java.util.zip.Inflater)
at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:128)
at java.io.DataInputStream.readFully(DataInputStream.java:266)
at java.util.jar.JarFile.hasClassPathAttribute(JarFile.java:423)
at java.util.jar.JavaUtilJarAccessImpl.jarFileHasClassPathAttribute(JavaUtilJarAccessImpl.java:15)
at sun.misc.URLClassPath$JarLoader.getClassPath(URLClassPath.java:803)
at sun.misc.URLClassPath.getLoader(URLClassPath.java:289)
- locked <0x2cfd8868> (a sun.misc.URLClassPath)
at sun.misc.URLClassPath.getResource(URLClassPath.java:156)
at java.net.URLClassLoader$1.run(URLClassLoader.java:191)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
- locked <0x2cfd85a8> (a java.net.URLClassLoader)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
Dynamic libraries:
0x8048000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/bin/regcomp.bin
0x2808f000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libuno_sal.so.3
0x2823b000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libuno_cppu.so.3
0x2826f000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libuno_cppuhelpergcc3.so.3
0x282cd000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libstlport_gcc.so
0x28375000 /lib/libm.so.4
0x2838b000 /usr/lib/libpthread.so.2
0x283b0000 /lib/libc.so.6
0x28487000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libuno_salhelpergcc3.so.3
0x2849c000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/servicemgr.uno.so
0x284ba000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/shlibloader.uno.so
0x284c0000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/simplereg.uno.so
0x284d0000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/nestedreg.uno.so
0x284df000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/typemgr.uno.so
0x28502000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/implreg.uno.so
0x28515000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/security.uno.so
0x28530000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libreg.so.3
0x2854d000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libstore.so.3
0x28b48000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/regtypeprov.uno.so
0x28b8d000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/javaloader.uno.so
0x28b94000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libjvmaccessgcc3.so.3
0x28ba8000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/javavm.uno.so
0x28bc2000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libjvmfwk.so.3
0x28bdd000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/libxml2.so.2.6.17
0x28cd3000 /lib/libz.so.3
0x28ce3000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/sunjavaplugin.so
0x28cf5000 /usr/local/jdk1.4.2/jre/lib/i386/client/libjvm.so
0x29122000 /usr/lib/libstdc++.so.5
0x291ec000 /usr/local/jdk1.4.2/jre/lib/i386/native_threads/libhpi.so
0x291fa000 /usr/local/jdk1.4.2/jre/lib/i386/libverify.so
0x2920f000 /usr/local/jdk1.4.2/jre/lib/i386/libjava.so
0x2922d000 /usr/local/jdk1.4.2/jre/lib/i386/libzip.so
0x35040000 /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/solver/680/unxfbsd.pro/lib/uriproc.uno.so
0x2805b000 /libexec/ld-elf.so.1
Heap at VM Abort:
Heap
def new generation total 576K, used 122K [0x2cfc0000, 0x2d060000, 0x2d4a0000)
eden space 512K, 24% used [0x2cfc0000, 0x2cfdebd0, 0x2d040000)
from space 64K, 0% used [0x2d040000, 0x2d040000, 0x2d050000)
to space 64K, 0% used [0x2d050000, 0x2d050000, 0x2d060000)
tenured generation total 1408K, used 0K [0x2d4a0000, 0x2d600000, 0x30fc0000)
the space 1408K, 0% used [0x2d4a0000, 0x2d4a0000, 0x2d4a0200, 0x2d600000)
compacting perm gen total 4096K, used 895K [0x30fc0000, 0x313c0000, 0x34fc0000)
the space 4096K, 21% used [0x30fc0000, 0x3109fdc0, 0x3109fe00, 0x313c0000)
Local Time = Mon Feb 6 14:36:52 2006
Elapsed Time = 0
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2-p8-root_06_feb_2006_10_48 mixed mode)
# An error report file has been saved as hs_err_pid66044.log.
# Please refer to the file for further information.
Abort (core dumped)
dmake: Error code 134, while making '../../unxfbsd.pro/lib/uno_services.rdb'
dmake: '../../unxfbsd.pro/lib/uno_services.rdb' removed.
'---* tg_merge.mk *---'
ERROR: Error 65280 occurred while making /usr/ports/editors/openoffice.org-2.0/work/OOA680_m1/testtools/source/bridgetest
dmake: Error code 1, while making 'build_instsetoo_native'
*** Error code 255
Stop in /usr/ports/editors/openoffice.org-2.0.
